Home > Technical > Service additives
spudfan
Ireland
Service additives
Have noticed that on the two occasions my Puma was serviced at the dealers the invoice mentioned
CLEANER AUTOMAINTAIN.Checked out the AUTOMAINTAIN website. They have a number of interesting items.The" Fuel system clean and restore" cleans your injectors and also your EGR valve. Use once every 10,000 miles.
They also do an "Oil system clean and restore" which you use during oil changes to clean out your engine and stop crappy build ups.
Anyway this might be of interest to someone.
Not sure which was used in mine, the fuel system one or the engine oil one. Any luck it will be both! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #36692 21st Jul 2010 12:59pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Yeah, noticed the same on my 24 month service with my new dealer last month, £11. On the 12 month service with my previous dealer it was merely called 'diesel additive' and was £22! I queried this at the time as I was under the impression that Land Rover do not recommend the use of fuel additives (may invalidate the warranty) and was informed that they intended discontinuing the practice! Makes you wonder!
Post #36712 21st Jul 2010 7:22pm
Grockle
I use some diesel additive that we use in the jag once a month, except I get it for free,our service manager says it does work and is worth using 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #36728 22nd Jul 2010 7:50am
spudfan
Ireland
Have an e-mail from AUTOMAINTAIN stating that the fuel system cleaner is safe to use in the Defender 2.4 Tdci engine. Also it will keep your EGR valve clean. One shot every 10,000 miles does not seem bad. 1982 88" 2.25 diesel
Post #36732 22nd Jul 2010 11:39am
mse
I had heard that too. Mike
Post #36735 22nd Jul 2010 12:02pm
Laurie
Do they just pour it in the tank, to settle at the bottom and regardless of how much fuel you have on board?
Sounds like a recipe for disaster Shocked
Post #36739 22nd Jul 2010 12:53pm
Naks
Laurie wrote:
Do they just pour it in the tank, to settle at the bottom and regardless of how much fuel you have on board? Sounds like a recipe for disaster Shocked
Hmm, with most additives, the instruction says to add it to an near-empty tank and then fill up. This ensures that the addivtive is mixed in with the diesel.
Btw, I stick a bottle of Wynns diesel cleaner in the spare tank every 5000km or so. It kills off any bacteria that may grow in the tank/lines, and that also cleans the injectors. I learnt about this product when I put a bottle in SWAMBO's Audi A3 TDi - it drank some bad diesel and was not well at all. She is now running better than when she was new Thumbs Up
Post #37295 29th Jul 2010 1:53pm
