Home > Tdi > Injector pump and injector servicing intervals |
watsons diesel are good , have used them couple of times , and a few others I know have used them and never heard anything bad
injectors and pumps are quite expensive where ever you go if you want them to be done right Watson (Diesel) Ltd Ronian Works Elm Grove Industrial Estate Wimbledon LondonSW19 4HE ENGLAND |
23rd Oct 2014 2:18pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Pull the pump and squirters and have them tested. I've used kent diesel services in maidstone before as they're bosch agents and found them good. Be aware that with a bit of shopping around you'll get a new pump for around the £500 quid mark may be worth going down that route if yours turns out to be trashed and needs mega bucks spent to repair. The injectors are quite expensive to do compared to 300 tdi ones but don't be put off its well worth doing.
23rd Oct 2014 4:32pm |
if you can I would say get new pump and injectors if funds allow and if they needed of course , recon never seen to be as good
if there new you know there right , recon you can never be 100% |
23rd Oct 2014 4:34pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
yep get genuine! only £3500 inc vat!!! in fact get a spare one while your on My 109 thread
my youtube channel |
23rd Oct 2014 5:23pm |
Ouch! Wonder how they factor in the extra £3K!!!! Handling charges????
23rd Oct 2014 5:35pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Thanks munch! Will give them a ring and see what they think.
It's one of those things which, its working fine and I'm loathed to fiddle with it. But I have heard they need to be refurbished every 100k miles, which is now over by a half so may be worth looking into. I'm half tempted by Turner engineering as they do new ones on an exchange basis, but £100 (with surcharge deducted) each is £400 which is alot of money.
Oh well if its that cheep I may as well get a spare set
Well you see, we saw you coming sir.... |
23rd Oct 2014 7:50pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
When we need specialist diesel services at work we have used Injection Developments at Bridge near Canterbury they have been very good,sorry don't have their number to hand but a quick search should throw it up. 2005 Td5 90 XS
Steve |
23rd Oct 2014 8:20pm |
I have friends in Canterbury so would be a good excuse to go and see them.
Will give them a ring tomorrow |
23rd Oct 2014 8:47pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
Paddocks sell recon'd injectors £140 a set but reqire your old units this is the rout i am taking as i think my injectors need doing Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
23rd Oct 2014 11:14pm |
Do you have a link for that Cornish? Sound way too cheep for a set of 4 but if it is correct I wont complain
24th Oct 2014 8:40am |
24th Oct 2014 9:41am |
Sorry i read the wrong vehicle for the injectors they gave a date of up to 89 forgetting mine had been changed to a 200tdi which paddocks don't list Graham 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
22nd Dec 2014 9:00pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
Whereabouts did you hear this? Mine have done 215,000 miles so I'm wondering if there's any mileage in getting them reconditioned. I just put a reconditioned pump on as the original was leaking and that has made a bit of a difference to power so I'm guessing the injectors will be similarly worn. Trouble is it's one of those things where you don't want to fiddle and create problems when it's all working fine as it is... |
23rd Dec 2014 5:55pm |
Do you know I have completely lost that reference.
I was convinced it was in the owners manual somewhere but can't find it. I know exactly what you mean though, don't touch what isn't broke. I still haven't done mine as I bottled out of taking them out as they seem to be working ok. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
23rd Dec 2014 7:47pm |
