![]() | Home > Td5 > Brodit Clip |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
The bracket fits on the top rail and can go almost anywhere. I have mine between the ashtray and the instrument cluster.
![]() Click image to enlarge ![]() Click image to enlarge Hope that helps. Cheers Simon |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
![]() @couplands - You keep your Landy in the kitchen Simon?... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
^^^of course, doesn't eveyone...?
Thieving b'stards mean I keep it well hidden... ![]() Cheers Simon |
I've got too admit, if I was thinking of nicking a Landrover I certainly wouldn't look in a kitchen for one
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 ![]() ![]() ![]() |
Perfect Simon. Many thanks
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 ![]() ![]() ![]() |
Simon
Is that an iPad holder on the left of that picture? Keith |
Yes it is. It's a RAM Mount fitted to a ball arm. The other end of the arm is fitted to a ali plate fitted from the top rail to the bottom.
Can take more pics if you want..? Cheers Simon |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 623 ![]() ![]() ![]() |
Yes please!
Just bought a ram mount and trying to figure out the best way to fix it to the dash. I would be particularly interested in your ali plate, how you fixed it and what thickness you chose. I've just ordered a 3mm bar and trying to work out how to bend it. |
If you wouldn't mind taking just one or two I would appreciate it thanks.
Regards Keith |
I think the Ali was 3mm. It's fairly strong and doesn't flex much. I bent it using my Black & Decker work mate, but I guess any vice would work well. Just use a piece of wood and a hammer or mallet to bend it over.
Here are some pics, hope they make sense. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cheers Simon |
Excellent thank you for that.
Keith |
