Home > Wheels & Tyres > Heavy Duty Steel Wheels (Wolf)
Page 5 of 16 <123 456 ... 141516>
duckworthparts wrote:
to clear things up error my mistake, didn't mean load rating.
As Cuthbert has said this relates to the axles on the heavy duty axles 3500kg
Dan - can you point me to a link or any further info on these 3500kg heavy duty axles & do you have any info on the load rating of the HD steel wheels? Do LR provide any extra info to you?
Post #366648 23rd Oct 2014 3:15pm
duckworthparts
Site Sponsor
i'm still trying to get some info out of LR no luck with a load rating at the moment though https://www.facebook.com/duckworthparts
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #366652 23rd Oct 2014 3:30pm
To the best of my knowledge there is no such thing as a "heavy duty axle". Some 110 and 130 models have HD suspension giving them a GVW of 3500kg rather than the standard GVW of 3040kg, however the axles are exactly the same and only the springs differ. There has never been a standard Landrover with a GVW in excess of 3500kg, and if there was one it would cause enormous complications with respect to vehicle classification, driver licencing, Operator Licencing, etc.
Similarly there is no such thing as an axle rated at 3500kg, since standard axles when used with the appropriate suspension allow a GVW of 3500kg.
Military axles are reinforced but the reinforcement does not alter the max. permissible axle load nor the GVW.
The genuine "Wolf" steel wheel is believed to be rated at 2200kg per wheel, but although this figure is widely circulated it seems that it is impossible to trace any definitive source for this. It is however the strongest wheel available off-the-shelf to fit a Defender, and LR has stated that the Wolf wheel shod with 7.50 Michelin XZL is the strongest wheel and tyre combination supplied.
This thread has drifted a long way from the OPs question and seems to have lost the plot! The actual load rating of the Wolf wheel is not (as stated on page 4) "the million dollar question", it is really irrelevant, since the limiting factor is firstly the law and secondly the chassis and suspension. You will be illegal long before anything breaks, and the wheel is likely to last longer that the rest of the vehicle.
Post #366665 23rd Oct 2014 4:39pm
Grouse
I think the point about the interest in the load rating of the Wolf Wheels, is that it gives an indication of inbuilt strength and not the intention for many of us to load the vehicle up to max weight - plus who wants a fake.
Mine is used off road every week, over very muddy and rocky terrain whilst heavily loaded - the Wolf's are strong enough to take this use - especially where rims can be caught by rocks etc, which would destroy and deform lesser wheels.
Anybody who has not examined a genuine Wolf will be stunned by the steel thickness and inherent strength of these wheels, its been said before - the military use them as they are virtually bomb proof.
If I wanted another set, I would be buying Genuine LR items off Dan at that price, the peace of mind is worth a couple of extra quid over unknown suppliers Very Happy
Post #366669 23rd Oct 2014 4:48pm
Grouse wrote:
... Anybody who has not examined a genuine Wolf will be stunned by the steel thickness and inherent strength of these wheels...
...and the weight! They are seriously heavy!
Post #366670 23rd Oct 2014 4:50pm
Grouse
I know, I have one on one of my bonnets Laughing
Post #366671 23rd Oct 2014 4:52pm
ericvv
^^ And as if I do not know. In two weeks I have to lift all four of them with the Nokians installed as additional weight into the rear of my truck to take them to the dealer who will mount them on my truck for the winter... Each of those 4 is heavy as h€ll.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #366672 23rd Oct 2014 5:08pm
Only guessing but it does seems reasonable that this figure follows on from the highest rated maximum axle weight for a LR being 2,200kg. In a cross axled situation when one wheel is lifted off the ground then this full weight would be on the other single wheel. Thus each wheel is designed to this limit and rated accordingly.
I'll check mine over the weekend, as I would almost expect there to be a stamping to show this somewhere. Seem to think other LR alloys I've had, have had a kg loading stamped/moulded into them.
Eric - can you weigh one - interested to see how it stacks up against mine posted earlier.
Post #366675 23rd Oct 2014 5:26pm
ericvv
Post #366698 23rd Oct 2014 7:03pm
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Had my new Genuine steel wheels delivered by Dan (duckworths) very pleased with them heavy duty and much better then the bearmac alternatives I looked at, there really is a huge difference from genuine and the £40 offerings, I have had a really good look around and checked a lot of alternatives , off to paint tomorrow black ral 9005. The extra discount was also appreciated Thanks Dan Thumbs Up
Post #366757 23rd Oct 2014 9:20pm
shaggydog
I thought earlier Salisbury axles had a HD version that had additional welding on the inside of the casings?
There was the Standard Salisbury which came with "light duty" 110's for Station Wagons and Pick Ups and then the HD Salisbury which had extra welds and thicker innards for the "Heavy Duty" 110's like Hard tops and High Caps and some Station Wagons. The innards were exactly the same but the casing was different.
This might be where the confusion has creeped in from earlier models which haven't been produced for years
Not going to be a option for late Td5 onwards vehicles but I have a feeling my Salisbury was a HD version will have a look next week when its all apart.
Post #366791 23rd Oct 2014 11:05pm
ericvv
[quote="Supacat"]
Exactly 34.5 kilo or 76 lbs. One Land Rover Wolf wheel with a Nokian Hakkapeliitta LT 235/85R16 on it.
Post #366866 24th Oct 2014 2:25pm
Eric - thanks.
That seems entirely consistent with my brand new HD wheel fitted with Goodyear Wrangler MT/R LT 235/85R16 - total weight of 35.4kg.
Post #366874 24th Oct 2014 3:47pm
ericvv
Post #366878 24th Oct 2014 3:55pm
Cuthbert
I feel that we are getting closer to comparing apples with apples. It's great when the info starts flowing.
Post #366900 24th Oct 2014 5:17pm
