![]() | Home > Technical > Gear Selection Query |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
What gear box oil did you use? Defender 90 TD5 Station Wagon
Discovery 3 HSE BMW 330i Coupe |
Bruce S Member Since: 20 Jun 2009 Location: Stoke on Trent Posts: 17 ![]() ![]() |
I put ATF Dexron in the main gearbox, and gear oil 80/90's in the transfer box.
Are there better options? |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 588 ![]() ![]() ![]() |
Hi,
Dont think ATF is recommended anymore for the R380 which I am assuming you have as its a TD5. I use Redline MTL which is very similair to MTF94 which is the recommended oil but much better when cold. This is more expensive though at about £10 a litre. Steve |
Hi,
MTF 94 is the recommended oil. I use Difflock Evo 1, fully synthetic oil, which has transformed the box and has made it relatively quiet and smooth. Evo 1 is expensive at circa £20/ltr. It is important to use the correct oil in these boxes, so worth a review? Good luck. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4760 ![]() ![]() |
A number of years ago my 200 tdi went in for a service and then the gearbox became really difficult to use. Wrong oil was used. Once this was rectified the gear box returned to silky smooth operation-well as silky smooth as the gear change on a 200 Tdi gets! Always use what the handbook states not what the garage happen to have in stock. 1982 88" 2.25 diesel
