Home > Tdi > Starting Issue - bit concerning. *** FIXED***
shaggydog
Hi guys,
Right got a starting issue here, let me run you through it.
Key in, wait for glow plug light to extinguish, crank. engine starts up runs for a second then dies.
Key in, wait for glow plug light to extinguish, crank, engine starts up fine, throttle applied, slight splutter, rpm picks up then runs fine and no issue for the rest of the day.
Has only happened yesterday and now this morning.
Its weird because it is still starting on its first revolution so its still happy, its just not running after the initial start but it is running fine once you have given it a slight rev and then for the rest of the day it will happily run, pulls fine, no more smoke than usual for a Tdi.
I have a theory it is an electrical issue - ether glow plug related or stop solenoid issue - how can I test this?
Only other thing I can think of is knackered injector or lift pump issue but if it was surely it wouldn't run happily?
Any thoughts welcome Smile
Post #365139 17th Oct 2014 7:55am
munch90
I would go down to route of air in diesel not glowplugs etc
Post #365140 17th Oct 2014 8:03am
g-mack
split in your injector spill pipes? My 109 thread
my youtube channel
Post #365169 17th Oct 2014 9:54am
shaggydog
G-Mack you brilliant mind you! Thumbs Up
Had a look in and felt the pipes, guess what , no 4 was loose (again) and its spill of pipe has been rubbing on one of the High pressure injector pipes and looks like it has a weep so new ones on order and everything tightened up and moved clear.
Hopefully that should be the end of it!
Dog
Post #365199 17th Oct 2014 12:39pm
munch90
new ones on order ? you can get the pipe from any motorfactors in one metre lengths and just cut to what you want , normally about 3-4 quid
Post #365201 17th Oct 2014 12:44pm
shaggydog
Good Point, will give them a ring and cancel the order.
Would that clear nylon pipe do ad a stop gap until it arrives?
I don't fancy leaking diesel into the engine bay or worse on the road.
Post #365202 17th Oct 2014 12:54pm
munch90
no not diesel proof ,goes rock hard after a while . get the proper stuff any motorfactors will do it or even Halfords do it about £5
Post #365204 17th Oct 2014 1:01pm
g-mack
Thumbs Up Thumbs Up
sounded just like what was happening to mine when i hadn't torqued up one of the banjo nuts!! as you hadnt been messing with your nuts {ooh er!} hose weas likely candidate!
glad it was quick and easy to sort! My 109 thread
my youtube channel
Post #365206 17th Oct 2014 1:11pm
shaggydog
Ohh did not know that! Thanks for the heads up!
Will toddle down to Halfords once the delivery man and the shed man have been.
One of those days - "we will deliver/collect between 8:30 and 17:00"
Quote:
sounded just like what was happening to mine when i hadn't torqued up one of the banjo nuts!! as you hadnt been messing with your nuts {ooh er!} hose was likely candidate!
As one of mine was on its way to loose I have a feeling the Copper washers have work hardened a bit so will make some new ones on Monday Very Happy
If its not the nuts, blame the hose! Whistle
Me too Very Happy makes a welcome change to have an issue at 7.30, diagnose it at 10, and fix it by 11!
Post #365227 17th Oct 2014 2:30pm
