![]() | Home > Tdi > Starting Issue - bit concerning. *** FIXED*** |
I would go down to route of air in diesel not glowplugs etc
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
split in your injector spill pipes? My 109 thread
my youtube channel |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
G-Mack you brilliant mind you!
![]() Had a look in and felt the pipes, guess what , no 4 was loose (again) and its spill of pipe has been rubbing on one of the High pressure injector pipes and looks like it has a weep so new ones on order and everything tightened up and moved clear. Hopefully that should be the end of it! ![]() |
new ones on order ? you can get the pipe from any motorfactors in one metre lengths and just cut to what you want , normally about 3-4 quid
Good Point, will give them a ring and cancel the order.
Would that clear nylon pipe do ad a stop gap until it arrives? I don't fancy leaking diesel into the engine bay or worse on the road. |
no not diesel proof ,goes rock hard after a while . get the proper stuff any motorfactors will do it or even Halfords do it about �5
![]() ![]() sounded just like what was happening to mine when i hadn't torqued up one of the banjo nuts!! as you hadnt been messing with your nuts {ooh er!} hose weas likely candidate! glad it was quick and easy to sort! My 109 thread my youtube channel |
Ohh did not know that! Thanks for the heads up! Will toddle down to Halfords once the delivery man and the shed man have been. One of those days - "we will deliver/collect between 8:30 and 17:00"
As one of mine was on its way to loose I have a feeling the Copper washers have work hardened a bit so will make some new ones on Monday ![]() If its not the nuts, blame the hose! ![]()
Me too ![]() |
