Home > Td5 > Alarm sounding when battery disconnected |
Get someone with a Nanocom or similar to alter the settings on the alarm.
15th Oct 2014 7:31pm |
Hi Simon, I guess you know you have to remove the key after turning ignition on/of, and remove negative terminal first? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
15th Oct 2014 8:09pm |
if you have battery back Alarm sounder it is work as it should
15th Oct 2014 9:06pm |
the back up sounder should not go off if you turn ign off then disconnect battery within 10-15 secs as in first post ,
I've never bothered taking the key out just turn off before disconnecting battery can't remember the time you have to disconnect battery after turning ign off , but 15 secs doesn't ring a bell , take you have tried disconnecting as soon as possible I would check all the fuses to do with alarm , think there are 2 or 3 fuses to do with alarm |
15th Oct 2014 9:16pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Vincent, Yes, removed the key and also tried both keys. I removed the earth ASAP, certainly less than 15 secs after removing key. cheers Simon |
15th Oct 2014 9:57pm |
The 15 sec is what is stated in the owners handbook....and it has worked before so I'm a bit stumped... Cheers Simon |
15th Oct 2014 9:59pm |
ok couldn't remember the time allowed to disconnect
15th Oct 2014 10:03pm |
Connect a battery charger and then remove battery? Cheers, Vincent
16th Oct 2014 5:59am |
^^^ I only need to swap a winch cable over, so will disconnect the battery and suffer the alarm for a few minutes...
Perhaps a pair of ear defenders is the answer... Cheers Simon |
16th Oct 2014 10:13pm |
