Home > Td5 > Alarm sounding when battery disconnected
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I can't disconnect my battery without the alarm going off.
I have used the process of turning the ignition on/off and disconnecting the battery within 15 seconds, but it always triggers the alarm. It has worked in the past, but not now.
Any ideas what I need to check..?
Simon
Post #364736 15th Oct 2014 7:54pm
JWL
Get someone with a Nanocom or similar to alter the settings on the alarm.
Post #364748 15th Oct 2014 8:31pm
VeeTee
Netherlands
Hi Simon, I guess you know you have to remove the key after turning ignition on/of, and remove negative terminal first? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #364754 15th Oct 2014 9:09pm
dorsetsmith
if you have battery back Alarm sounder it is work as it should Exclamation
Post #364783 15th Oct 2014 10:06pm
munch90
the back up sounder should not go off if you turn ign off then disconnect battery within 10-15 secs as in first post ,
I've never bothered taking the key out just turn off before disconnecting battery
can't remember the time you have to disconnect battery after turning ign off , but 15 secs doesn't ring a bell , take you have tried disconnecting as soon as possible
I would check all the fuses to do with alarm , think there are 2 or 3 fuses to do with alarm
Post #364789 15th Oct 2014 10:16pm
couplands
Vincent,
Yes, removed the key and also tried both keys. I removed the earth ASAP, certainly less than 15 secs after removing key.
cheers
Simon
Post #364810 15th Oct 2014 10:57pm
couplands
The 15 sec is what is stated in the owners handbook....and it has worked before so I'm a bit stumped...Sad
Simon
Post #364814 15th Oct 2014 10:59pm
munch90
ok couldn't remember the time allowed to disconnect
Post #364816 15th Oct 2014 11:03pm
VeeTee
Netherlands
Connect a battery charger and then remove battery? Cheers, Vincent
MySite
Post #364839 16th Oct 2014 6:59am
couplands
^^^ I only need to swap a winch cable over, so will disconnect the battery and suffer the alarm for a few minutes... Shocked
Perhaps a pair of ear defenders is the answer...Smile
Simon
Post #365109 16th Oct 2014 11:13pm
