Home > Puma (Tdci) > over revving during gear change
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Hi all,
I have a problem when changing gear, especially the low gears (1st./2nd/3rd).
When the clutch is depressed to change gear and the foot is raised from the accelerator the revs continue to increase momenterally e.g. the revs don't drop instantly, it rises briefly.
Seems more noticeable when the engine is cold.
Any comments on experiences
El pepe flamenco JLS
'El Pepe Flamenco'
Post #36455 16th Jul 2010 11:18pm
LROV90
Australia
What that will be is the clutch switch not working. On the top of the clutch master cylinder there is a pressure switch which is linked to the engine ecu that commands reduced revs when the clutch pedal is pressed.
There could be two causes for the switch not working. It's Censored , or the fuse is blown. The fuse is the same one as the brake lights. So you can quickly check if is blown by making sure the brake lights are working. Often using a trailer with bad wiring will blow the brake light fuse.
Good luck!
Post #36456 17th Jul 2010 12:04am
jlerra
over revving on changing gear
Thanks for the tip LROV90.
I shall investigate further.
regards
Joe
'El Pepe Flamenco'
Post #36464 17th Jul 2010 8:00am
Forest of Dean 90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
"Often using a trailer with bad wiring"
Don't they all have Bad Wiring Laughing I've very rarely found one that everything works on, without having to fiddle them..
Post #36477 17th Jul 2010 1:13pm
bjartin
Norway
I'm having the same problem after I installed Cruise Control. It was not something I noticed before I had installed Cruise Control. The symptoms are exactly as you describe. My workshop canīt come up with a solution, must wait for the latest software. (???). Puma 90 MY 2010 (sold 2017)
Defender 110 MY 2001
http://www.youtube.com/bjartin
Post #36482 17th Jul 2010 2:13pm
jlerra
'over-reving' during gear change
Hi all,
Have been in touch with my dealer (who are pretty good and very obliging - contrary to many general comments about dealership) who is investigating with LR about the software/master cylinder switch/brake fuse and they will give me feedback prior to taking the truck in for correction.
Will keep you informed of what happens.
Joe
'El Pepe Flamenco'
Post #36553 19th Jul 2010 11:17am
bjartin
Norway
Re: 'over-reving' during gear change
jlerra wrote:
... they will give me feedback prior to taking the truck in for correction.
Joe
El pepe flamenco
Hi Joe
Have you received any feedback that you want to share with us!
bjartin
waiting anxiously. Puma 90 MY 2010 (sold 2017)
Post #38851 22nd Aug 2010 4:21pm
jlerra
Hi,
Sorry for the delay in posting the result of the problem with the 'overring when changing gear'.
Thanks to LROV90 and his advice I took the vehicle to the dealer and they changed the Clutch Switch on top of the master cylinder which signals the ECU to drop the revs on gear change and the result........100% cured the problem.
So, off you go to the dealer and insist on them changing the Clutch switch on top of the master cylinder and all should be fine again.
Good luck
Joe
'El Pepe Flamenco'
Post #38853 22nd Aug 2010 4:32pm
bjartin
Norway
Joe, thanks for the quick reply.
Next Monday I have an appointment with the workshop and they will get a copy of your post
---- hence my problem will be history
Many thanks Joe. Puma 90 MY 2010 (sold 2017)
Post #38854 22nd Aug 2010 4:49pm
jlerra
0verreving problem on gear change
Pleasure to be of help!
Also thanks need to go to LROV90!
Joe
'El Pepe Flamenco'
Post #38856 22nd Aug 2010 4:54pm
LROV90
Australia
No probs!
Post #38878 23rd Aug 2010 12:27am
bjartin
Norway
Now is also my 90" healed, thanks to this knowledgeable and helpful forum. ( this time read LROV90 ). Puma 90 MY 2010 (sold 2017)
Post #39607 2nd Sep 2010 2:59pm
Andrea
Hi there.
I have had the exact problem with my puma and after much searching for the problem, (the dealers say that its a clutch switch or what not that they are changing but actually it is a fuse. You will notice that it starts doing it after towing> sometimes the trailer shorts witht the car and blows a fuse. Check the fuses in the driver legwell, not under the seat, will be 100%.
Good luck
Post #39634 2nd Sep 2010 7:33pm
AndrewS
Thumbs Up 130's have feeling's as well you know Smile
Post #39635 2nd Sep 2010 7:48pm
