Home > Puma (Tdci) > Coolant Change
davidpalfreyman
2009 Defender 110 Puma 2.4 CSW Alpine White
Coolant Change
Help please:
I want to change the coolant. How do you remove the pipes from the fuel cooler in order to drain it?
Never seen clips/connections like those before.
The manual also shows a picture of the hose that has to be removed from the 'oil thermostat'.
The drawing in the manual looks a little like the pipe that goes to the oil cooler above the oil filter. Is that the one?
Thanks so much for any suggestions
David P
Post #364203 13th Oct 2014 5:59pm
