Home > In Car Electronics > puma speaker size and radio connector |
jav-uk Member Since: 29 Mar 2010 Location: Shropshire Posts: 112 |
Hi,
For most head units you need an iso adaptor cable for 2010 model year onwards. Check with the radio supplier before you buy that it is iso. Speakers are 100mm under dash. Finding the cables is fun, they are taped up inside the dash and not that easy to locate. Mudstuff have lots of bits to help you fit everything. FYI The iso adaptor i received needed the light cable moving to illumiinate the radio, the pins push out using a watchmakers screwdriver pushed against the small retaining clip. Paul Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
4th Mar 2014 8:44am |
easydeluxe Member Since: 18 Nov 2013 Location: antwerp Posts: 55 |
thank you very much
4th Mar 2014 8:58am |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2760 |
not sure if you have 'halfords' or similar across the channel, but if you go to them they will give all the information you need, and will probably stock a suitable radio, speakers and any connectors required Cheers, David
Land Rovers of all shapes S3 onwardsโฆ Daily is a 110 V8. |
4th Mar 2014 1:31pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20479 |
Above is all correct, the speakers are 10cm, but you will need to likely fit aftermarket connectors or at least one. Also although the size of 10cm is standard to get the speaker and grille to sit in its correct orientation and not at a 45degree angle you may have to drill screw holes. (See my gallery) No Guts, No Glory.
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
4th Mar 2014 2:22pm |
Thank you. My LR dealer said that they usually just solder in the iso connector.
I chose an Alpine 173 BT head unit and 10 cm Pioneer speakers. My local car audio shop quoted me 230 euro for head unit, speakers and fitting. Thanks for all the advice. |
4th Mar 2014 6:32pm |
No Guts, No Glory.
4th Mar 2014 6:46pm |
Carrotious Member Since: 21 Mar 2014 Location: Geneva Posts: 24 |
Hi all, am in the same situation, new 2014 90 SW .
There are what look like rear speaker reservations in black plastic panels facing forward either side of the rear door. Does anyone know if there is cabling to the rear as there is cabling factory standard to the front and tweeters? Cheers G |
26th Mar 2014 9:18pm |
There should be but might be hidden and tied up with other wires behind there. Shouldn't be too difficult to check. No Guts, No Glory.
26th Mar 2014 10:11pm |
natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 136 |
Hi silly question , I am in the same boat as Easydeluxe found drivers side speaker wiring , and now sorted the radio wring , but cannot see the passenger side speaker wires any where
Help! 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb 2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
27th Sep 2014 4:55pm |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Can you confirm the colours of the speaker wires hidden up under the dash?
11th Oct 2014 8:29pm |
I just rewired from behind the radio in the end , sorted now 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
13th Oct 2014 11:33am |
