Home > In Car Electronics > puma speaker size and radio connector
easydeluxe
Belgium 2008 Defender 90 Puma 2.4 HT Epsom Green
Sorry if it's been beaten to death already...
But in a few days my new 2014 90 arrives without a factory radio installed.
I want to buy an Alpine radio and some speakers.
I want the simpelest plug and play solution possible...
2 questions:
-What is the the size of the speakers that go right in without customizing anything?
-Do you need a connector to plug the alpine into the Defender?If yes where to get?
thank you.
Geoffrey
Post #313329 4th Mar 2014 6:16am
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
Hi,
For most head units you need an iso adaptor cable for 2010 model year onwards. Check with the radio supplier before you buy that it is iso.
Speakers are 100mm under dash. Finding the cables is fun, they are taped up inside the dash and not that easy to locate.
Mudstuff have lots of bits to help you fit everything.
FYI The iso adaptor i received needed the light cable moving to illumiinate the radio, the pins push out using a watchmakers screwdriver pushed against the small retaining clip. Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #313357 4th Mar 2014 8:44am
easydeluxe
thank you very much
Post #313359 4th Mar 2014 8:58am
Cheshire110
not sure if you have 'halfords' or similar across the channel, but if you go to them they will give all the information you need, and will probably stock a suitable radio, speakers and any connectors required Cheers, David
Post #313422 4th Mar 2014 1:31pm
Above is all correct, the speakers are 10cm, but you will need to likely fit aftermarket connectors or at least one. Also although the size of 10cm is standard to get the speaker and grille to sit in its correct orientation and not at a 45degree angle you may have to drill screw holes. (See my gallery) ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #313431 4th Mar 2014 2:22pm
easydeluxe
Thank you. My LR dealer said that they usually just solder in the iso connector.
I chose an Alpine 173 BT head unit and 10 cm Pioneer speakers. My local car audio shop quoted me 230 euro for head unit, speakers and fitting.
Thanks for all the advice.
Post #313497 4th Mar 2014 6:32pm
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #313504 4th Mar 2014 6:46pm
Carrotious
Switzerland 2014 Defender 90 Puma 2.2 SW Keswick Green
Hi all, am in the same situation, new 2014 90 SW Very Happy .
There are what look like rear speaker reservations in black plastic panels facing forward either side of the rear door.
Does anyone know if there is cabling to the rear as there is cabling factory standard to the front and tweeters?
G
Post #319339 26th Mar 2014 9:18pm
There should be but might be hidden and tied up with other wires behind there. Shouldn't be too difficult to check. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #319375 26th Mar 2014 10:11pm
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Hi silly question , I am in the same boat as Easydeluxe found drivers side speaker wiring , and now sorted the radio wring , but cannot see the passenger side speaker wires any where
Help! 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #360540 27th Sep 2014 4:55pm
Cuthbert
Can you confirm the colours of the speaker wires hidden up under the dash?
Post #363842 11th Oct 2014 8:29pm
natyeo
I just rewired from behind the radio in the end , sorted now 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #364108 13th Oct 2014 11:33am
