Home > Puma (Tdci) > Turbo Wiring |
surf110 Member Since: 14 Jan 2008 Location: Rio de Janeiro Posts: 43 |
One of the wires split on my turbo plug.
Any ideas hoe to fix this? Cheers. https://www.defender2.net/gallery/albums/u...G_0863.jpg |
11th Oct 2014 4:48am |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Hi.
You can get a repair like mentioned here http://www.defender2.net/forum/topic24288....ring+turbo I had a broken wire on mine - added a new length of wire and it worked again - but there was a bit more wire after the plug. Best regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
11th Oct 2014 6:59am |
If you have a soldering iron you could solder a flylead to the connector and then inline splice to the existing detached cable perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
11th Oct 2014 7:49am |
take the terminal out of the plug , using very very small screwdriver ( terminals normally clipped in the plug by small metal clip on the terminal that needs the be released then pulled on of plastic plug) then solder flylead to terminal is I think what K9F is talking about
11th Oct 2014 2:06pm |
Yes if it is the right type of connector the terminals can be released with a small flatblade watchmakers/instrument screwdriver from the front and extracted individually. Some extract rearwards and some forwards dependant on the type of connector. Once finished it can simply be reinserted and it will lock automatically. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Oct 2014 3:27pm |
Was able to solder a flylead.
Thanks for the tips. |
16th Oct 2014 4:31am |
