Home > Puma (Tdci) > Puma smoking only on cold morning start ups.
Page 1 of 3 123>
CARMARK2014
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Cold mornings here again and my puma smokes for about 3 seconds then it clears, strange, as when the weather is warmer theres no smoke at all. Its only as the outside temp drops. I know it been mentioned before and I think it was said it could be a sensor, but which one can anybody help. Thanks. Question [/b] Defender 110
Post #363068 8th Oct 2014 9:52am
g-mack
condensation in pipe? is it white smoke? or more likely just steam? My 109 thread
my youtube channel
Post #363072 8th Oct 2014 10:04am
CARMARK2014
I think its more blue than white, that's why I think its a sensor as it seems to only do it when outside air temp is around 5 degrees or lower. Defender 110
Post #363075 8th Oct 2014 10:11am
g-mack
i don't know much about pumas, but blue smoke usually indicates burning oil.
think ive read glow plugs can cause blue smoke on cold morning start ups My 109 thread
my youtube channel
Post #363077 8th Oct 2014 10:17am
It seems to be very common for Pumas to make smoke for a few seconds immediately after cold start. If everything else is OK, I wouldn't worry about it.
Mine's been doing it for over 150,000 miles and has never got any worse (it's never got better either)!
Post #363102 8th Oct 2014 1:46pm
CARMARK2014
Everything else seem ok, I just thought it odd that it only does it when the weathers cold. Defender 110
Post #363108 8th Oct 2014 2:54pm
bob neville
Quite normal for the 2.4's, my 2009 110 did this on cold mornings.
The 2.2 does not seem to suffer from the same issue.
There are quite a few posts about it on here.
http://www.defender2.net/forum/topic12389....blue+smoke
2013 Defender 90 CSW - sold
Post #363140 8th Oct 2014 5:49pm
driver9
My 2.4 Puma does it when I don`t wait for the glow plug light to go out.
Post #363141 8th Oct 2014 5:51pm
CARMARK2014
Thanks all, I guess I will put up with it then. Smile Defender 110
Post #363165 8th Oct 2014 6:57pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Try 2 x Glowplug cycles before firing the starter, i.e.: Glowplugs on - wait for light out - ign off/on - Glowplug light goes out 2nd time- Starter. Any difference???
If so could be a Glowplug, but as long as it is starting OK - ignore. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #363272 9th Oct 2014 5:42am
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
My 2011 2.4 is the same, on cold mornings loads of white clag. The colder the morning the worse the white smoke and stink.
It's just unburnt diesel, it clears after a few seconds on mine, done it from new and a Transit van down the road is just the same.
Jonno
Post #363407 9th Oct 2014 4:55pm
CARMARK2014
This morning its very damp outside came out glow plug light on waited for it to go out engine turns but wont start, tried again glow plug light out, engine turns again wont start. I waited about 30 seconds tried again and it started, it as done the twice both on damp morning start ups, the rest of the day its started ok. Could it be a glow plug or do they all need changing my defender is 2008 with 30k on the clock.. Defender 110
Post #364917 16th Oct 2014 11:54am
Lorryman100
The white smoke in the cold mornings is unburnt diesel. The EMS overfuels on cold temps to start the engine and as the engine warms up less fuel is used in the burn. The EMS uses the information received from the CHT sensor to govern the fuelling file as to how much fuel is needed to start and keep the engine running within pre programmed norms, basically as the engine warms up less fuel is needed and it is the CHT sensor which tells the EMS what the actual head temp is. Fuel going into the cylinder is controlled by the solenoids on the individual injector which is controlled by the EMS. Again this is easy checked with a DMM as the EMS applies current to the injector solenoid valves in 3 stages:
1. 18 amps
2. 8 amps
3. 4 amps
HTH
Post #364939 16th Oct 2014 12:43pm
munch90
deleted
Post #364941 16th Oct 2014 12:50pm
110MGD
2001 Defender 90 Td5 CSW Epsom Green
My old Td5 does this as well, I am learning more and more not to look at the little things, at one point i'd be taking it in for every sqeak and rattle and water/ oil leak. Unless it's serious and hampers everyday use of the vehicle, or is obviously damaging it. I don't bother, cos i'd be bankrupt trying to fix everything on mine Laughing It still doesn't break down/grind to a halt so I am happy. 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #364945 16th Oct 2014 1:08pm
Page 1 of 3 123>
