Home > Td5 > Bearing change.
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Bearing change.
Still a few miles left in this.
I can't get to the ones on the other side as the drive member is seized on the shaft. It wasn't me!
Post #362046 3rd Oct 2014 10:35pm
mk1collector
Shocked that may need repairing!
Post #362053 3rd Oct 2014 10:59pm
JWL
You been letting Vikki drive again? Whistle
Post #362203 4th Oct 2014 7:09pm
ozzy57
 It wasn't me!
Post #362210 4th Oct 2014 7:39pm
JWL
Put up a bit of a fight then! Rolling with laughter
Post #362211 4th Oct 2014 7:41pm
JWL
You need some thinner discs for your grinder by the looks of things Oz.
Post #362212 4th Oct 2014 7:42pm
ozzy57
It wouldn't give up! It wasn't me!
Post #362213 4th Oct 2014 7:44pm
dorsetsmith
ozzy57 wrote:
do not give up mine had same problem two days to change front disc got it sorted in the end Exclamation
off side rusted to the spline had to use grinder too thin cutting disc and lot more parts Whistle
Post #362217 4th Oct 2014 7:50pm
ozzy57
And then the lights! ABS, TC and brake warning light. Big Cry It wasn't me!
Post #362219 4th Oct 2014 8:01pm
Ken B
Ah the three amigos!
Mine recently cured by running new earths to battery box and ECU/fuse box! Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #362220 4th Oct 2014 8:06pm
ozzy57
I have a sneaking suspicion the sensor may be upset after all the hammering , heating and grinding. It wasn't me!
Post #362225 4th Oct 2014 8:21pm
jimbob7
LOL,i had to cut the f/n/s flange off when I did my brakes last year anorl, Censored Censored Banging Head Pov.spec,ftw. 2006, 110,TD5.
Post #362227 4th Oct 2014 8:23pm
jimbob7
My sympathies,I'm still having flashbacks Big Cry Pov.spec,ftw. 2006, 110,TD5.
Post #362228 4th Oct 2014 8:24pm
JWL
And you thought you'd seen the last of the three amigos when you sold your Disco, eh Ozzy?
Post #362237 4th Oct 2014 8:49pm
