![]() | Home > Td5 > Bearing change. |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
![]() Click image to enlarge Still a few miles left in this. I can't get to the ones on the other side as the drive member is seized on the shaft. It wasn't me! |
You been letting Vikki drive again?
![]() Click image to enlarge It wasn't me! |
Put up a bit of a fight then!
You need some thinner discs for your grinder by the looks of things Oz.
It wouldn't give up! It wasn't me!
And then the lights! ABS, TC and brake warning light.
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 ![]() |
Ah the three amigos!
Mine recently cured by running new earths to battery box and ECU/fuse box! Defender 90 TD5 County - You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
I have a sneaking suspicion the sensor may be upset after all the hammering , heating and grinding. It wasn't me!
LOL,i had to cut the f/n/s flange off when I did my brakes last year anorl,
My sympathies,I'm still having flashbacks ![]() |
And you thought you'd seen the last of the three amigos when you sold your Disco, eh Ozzy?
