Home > Technical > How do a wire in a Buzzer to the Indicator Relay!
Page 2 of 2 <12
You'd have to be careful with the RDX relay that the trailer light isn't activated due to extra load.
That of course depends on the load put on of course, LED's which draw mA's wouldn't trigger it off but higher loads might.
Post #361396 1st Oct 2014 11:15am
rallysteve
Indeed that is the correct way to wire up as I described. The wiring diagram shows the flasher relay as being a normal coil/armature and contacts like a normal SPST relay; this is misleading as this is not all that it contains.
Is it not the RDX relay that is has an adjustable set point for the triggering of the trailer warning light? If so this could be adjusted to account for the buzzer current draw. For reference the rs components buzzer: http://uk.rs-online.com/web/p/buzzers/0245332/
has a current draw of 30mA at 12V (400Ohm resistance).
Post #361397 1st Oct 2014 11:29am
gilarion
Thanks guys for all the info, to be fair I think it all seems a bit complicated for my reduced auto electric skills, I will either keep my eye on the warning light or get a man in who knows what he is doing.
Trouble is the indicator cancelling has a mind of its own, sometimes it cancels, sometimes it does not. So I at times I unaware that the an indicator side is flashing as I drive down the road after turning, I have replaced the indicator switch with genuine parts about a year ago because of the same problem, thats two units in three years. Maybe its time to replace again.
Post #361405 1st Oct 2014 12:06pm
rally steve - That current draw would be acceptable because it's so low.
Post #361407 1st Oct 2014 12:11pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Unless it was just mine, didn't the really old Landies have them? My B reg Ninety used to make a hell of a buzz when indicating. 1998 110 300Tdi White Hard Top
Post #361443 1st Oct 2014 2:40pm
munch90
all the mucking about with diodes etc , have you looked at a audicator its does exactly what you want
don't know about the dash trailer light as I don't use one I use a 3 pin flasher and have a buzzer for trailer indicators
rdx relay no good for me as I have trailers with both led and normal bulbs ( 1 trailer with bulbs & 1 trailer with leds ) and a trailer board as well
Post #361485 1st Oct 2014 5:57pm
Page 2 of 2 <12
