Home > Maintenance & Modifications > Front and read doors hinges |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
I would be tempted by these if it was not for the obtrusive branding. I really wish suppliers would stop doing this, I drive a Land Rover not an ORP (or an Entreq or a ..... )
28th Sep 2014 9:55am |
Brian,
Increasing the picture size to 400% top picture have you sealed the securing bolts or is the surface finish around the bolts already showing signs of some deterioration? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Sep 2014 11:19am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
@Mal
When I removed the OEM hinges I used T cut to remove any etching from the paintwork. I then treated the bolt holes and then gave it a coat of carnauba wax. When I offered up the orm hinges they covered the original OEM hinges foot print. The orm hinges foot each got a coat of ac-50 corrosion block grease, as did each of the bolts. We'll the bolts got a very healthy covering as did the holes. What you are seeing is grease seepage which I neglected to completely remove. |
28th Sep 2014 1:46pm |
one of my pet hates also. |
28th Sep 2014 2:10pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5112 |
Have to second that! And not just on Land Rover after market products, but on so many other things as well. |
28th Sep 2014 2:48pm |
Thanks Brian,
Am leaning more towards a set each time the thread is revisited. Need to do something, it's a shame the stainless steel ones that used to be advertised on Smiling Hound's old website never came to fruition. There was loads of interest in the product itself but e-mail queries remained unanswered as did phone messages from many people.....if you can't deliver any service at the launch stage it's probably for the best it folded when it did. http://www.landyzone.co.uk/lz/f7/rear-door-hinge-134806.html http://www.defendersource.com/forum/archiv...36829.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Sep 2014 2:57pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Would a fine tip permanent marker not be enough to make the logo disappear? 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
28th Sep 2014 2:59pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Yrm have a pre order section for stainless, standard shape rear door hinges on their website |
28th Sep 2014 3:02pm |
Thanks MK1 just what I have been waiting for. Will give them a tinkle tomorrow. Nice one thanks again.
http://www.yrmlandrover.com/epages/BT3575....oducts/155 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Sep 2014 3:15pm |
To be honest I have never understood why Land Rover themselves have never come up with a better design for their door hinges. After all they have had seven decades to think about it. Seventy years ago it was OK I suppose to put a set of gate hinges on the back door, not so sure it cuts it nowadays on a vehicle that can cost upwards of over thirty grand.
28th Sep 2014 3:24pm |
Isn't that part of the idiosyncrasy and perhaps attraction of purchasing a 'warts 'n' all vehicle? After all something must give it it's cult following and enthusiasm?......Gate hinges, poor finish and internal shower when it rains aside of course. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Sep 2014 3:34pm |
only thing I would say is ive never had any trouble with any hinge on any land rover ive owned , I keep them well lubed and never had to replace anything |
28th Sep 2014 3:38pm |
The door hinges look good but at the price I am not 100% sure they would cover all of the OEM footprint. Fair enough I could make my own spacers but the picture shows them using the OEM spacers which are bigger than these hinges so not sure the difference would be visible in a bad way. The rear hinges are well made and definitely cover the OEM footprint plus the rear door does seem to open and close easier, placebo effect maybe??
I am wondering whether a set of OEM door hinges powder coated black would look just as good, providing they could be powder coated, anyone had this done? |
28th Sep 2014 3:51pm |
As stated I did a lot of research before buying replacement hinges.....Some you need to look out for due to size....
In sourcing good OEM hinges here are a few cut and pastes from another site. TD5 ones seem the best but need a little work and galvanising to make them last....You could then have them whatever colour you wish.....Excuse the longevity of this post..... Or knock the hinge pins out, wire brush them and get the hinges galvanised. Got a set of 4 hinges done for a fiver. Drill surplus galv out of hinge pin hole and fit new pins. With stainless bolts, job done, no more rust. The galv idea sound good but is actually flawed in practice because you'll have to remove the layer of glav from the hinge where the two halves of the hinge rubs together. This metal-to-metal contact is what causes the wear in the hinges and is what would also compromise the galvanising process. FWIW. Get yourself the later Td5 type hinges. These seem to resist rust better and have a nylon bush in the hinge to prevent the metal-to-metal contact. Try to get genuine LR hinges rather than aftermarket ones. The pattern hinges(S**tpart) we've been supplied in the past often have more slop in them than the knackered hinges we're looking to replace! True, but a light kiss with a file is all it needs. Had my galved hinges for 5 years now and they haven't worn through this"contact patch" yet. My original hinges were scrap by the time they were 5 years old, worn to , sagging and rusting. The rust tends to accelerate the wear on the contact patch. 5 years on the galv ones are good as new. I got brand new ones galved by the way. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Sep 2014 4:04pm |
