Home > Maintenance & Modifications > Lost a Mud Flap
theorangebandit
Lost a Mud Flap
well off roading yesterday saw me short a mud flap, the rear left . its has ripped the metal of the rear arch where it used to bolt on.
question is how do i improve this situation ? can i bolt on the 90 rears onto my cross member without impeding on the exhaust?
ill remove all of remaining flaps in the mean time although i worry i might prefer it without lol.
out of interest what are your verdicts on mud flaps, fitted or no.
Post #257884 11th Aug 2013 10:38am
bob neville
http://4x4overlander.com/entreq-products/e...ckets.html Thumbs Up
2013 Defender 90 CSW - sold
Post #257896 11th Aug 2013 11:09am
theorangebandit
not sure thats what im needing, the whole bracket has been taken clean off, he flap itself is still very attached to the arm lol
Post #257899 11th Aug 2013 11:12am
theorangebandit
infact on second looking that looks like its meant to reinforce the lip of the arch am i correct ?
Post #257900 11th Aug 2013 11:13am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Thumbs Up you got it! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #257902 11th Aug 2013 11:16am
theorangebandit
i am buying them bad boys !
thanks for the find bob neville thread closed lol
Post #257904 11th Aug 2013 11:18am
Cat81
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Orkney Grey
I just lost my 2 rear mudflaps (!) to the same issue. Wheel arch broke at the fixation point. This looks like a great solution although I am now worried to tear the whole thing apart.
Is it possible to fix 90 mud flaps to a 110 (the ones that go on the cross member)?
Post #360701 28th Sep 2014 8:34am
leeds
Yes I would think it is possible to fit 90 rear mud flap brackets to a 110.
However because the rear mud flaps are now set back further then normal they may well not control water spray so effectively on a wet road.
It may be a better idea to use the strengthening/repair brackets on the body panel and drill a small hole in the bottom of the rear mud flaps and attach a baby shackle etc and just tie the rear mud flaps up onto rear bumperettes etc. when going offroad.
Brendan
Post #360709 28th Sep 2014 9:03am
landy andy
Or buy Gwyn Lewis reinforced quick removal mud flaps. That's my plan.
http://www.gwynlewis4x4.co.uk/product/defe...quare-tub/
Andy
Post #360717 28th Sep 2014 10:21am
Cat81
Thanks Brendan that sounds like a plan. Andy, these are nice, but also ... 100+ quid!
Post #360901 28th Sep 2014 9:02pm
Eduardo
Happens the same to me several years ago.
1st try to straighten the tab were the mudflap is attached.
Buy a L shape 20x20x1 mm aluminium, cut in a +/- 150 mm long make an hole to put again the bolt and rivet or bolt it to the tab of the panel in 4 points.
1/2 hour work.
Cheers Eduardo
Post #360910 28th Sep 2014 10:58pm
