Home > Technical > Leaking Pink
Appleby
United Kingdom 2002 Defender 90 Td5 CSW Epsom Green
Leaking Pink
Evening all,
I moved my Td5 90 today after its been sat in my garage for a couple of weeks. It seems to be leaking a pink fluid from around the transfer box and under the engine. From a bit of reading it seems that the transfer box likes to leak a little but I'm wondering if this is the cause? Any suggestions?
Thanks
Smile
Post #360562 27th Sep 2014 6:04pm
dorsetsmith
Antifreeze OAT
Post #360564 27th Sep 2014 6:09pm
LR90XS2011
Sad DEFENDER 90 TDCI XS,
Post #360582 27th Sep 2014 7:10pm
bear100
Ep90 differential oil is a pinky red colour Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #360589 27th Sep 2014 7:30pm
dorsetsmith wrote:
Antifreeze OAT
Sounds like that to me too.
Post #360592 27th Sep 2014 7:33pm
Happyoldgit
Smell it, no really, get a drip on your finger and smell it. Then see if it feels oily or not, does it diminish if you rub it between your fingers or does it still feel like a lubricant. Steve.
http://forums.lr4x4.com
Post #360598 27th Sep 2014 7:52pm
ickle
Reminds me of a few years ago waiting to get on the St Malo overnight ferry, gent next door knocked on the window and told me I had fluid dripping off the underside - reached under, dipped my finger in, smelled sweet, tasted sweet and oily, made the snap decision to travel and sort it out in France. Got on board and checked level of coolant, it was OK and pink, fluid underneath was blue.
My daughter them informed me she had knocked over her slush puppy iced drink in the rear seat footwell - I haven't been so happy that I had a sticky mess in the back seat since I last swerved to avoid a child!
Keith
Post #360608 27th Sep 2014 8:18pm
ZeDefender
Check the cap on the coolant tank. Some of them start to leak after a few years (at least on the Pumas). Tell someone you love them today because life is short.
Post #360667 28th Sep 2014 6:59am
K9F
On the flightline in Cyprus years ago waiting for the crew to turn up I was absolutely busting a gut for a pee so let one go by the starboard underwing fuel tank. Did chuckle when the pilot did his walkround, dipped his finger in it and gave it a sniff thinking it was aviation fuel.
Shocked Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #360692 28th Sep 2014 8:17am
rallysteve
Ep90 gear oil is a golden/greenish colour. Atf however is a red/cherryaid colour Wink 02' 110 TD5 Double Cab Rebuild Thread
Post #360704 28th Sep 2014 8:46am
landy andy
Mtf, your gearbox oil is red.
Sniff taste test is they best way to know.
Post #360716 28th Sep 2014 10:18am
Appleby
dorsetsmith wrote:
Antifreeze OAT
Give that man a cigar! Having a look in the light of day it is definitely Antifreeze. It's not oily and theres too much of it too far forward to be anything else. Also I probably should have checked yesterday but the expansion tank was pretty much empty! Dead giveaway! Unfortunately it does look like a lot has escaped and has dripped all down the passenger side of the engine bay (a puddle under where the turbo is). I tried to find the source of the leak but couldn't see where it was coming from. Are there any common sources or areas I should check?
Thanks
Post #360723 28th Sep 2014 10:41am
dorsetsmith
pint instead if passenger side check heater rad Exclamation
Post #360742 28th Sep 2014 11:40am
landy andy
There is a core plug in the cylinder head, in the middle of the exhaust manifold, that often leaks.
Andy
Post #360748 28th Sep 2014 12:13pm
Laurie
If it's 'oily' it's gearbox oil or power steering fluid.
If it's not 'oily' it's antifreeze,
Post #360914 29th Sep 2014 12:48am
