Home > My Defender > What Did You Do In Your Defender Today |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Well front propshaft and transmission output seal changed.
Rear next and once I got it off found the the cause of the rear vibration . Click image to enlarge |
18th Sep 2014 12:41pm |
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 |
Eric, if the tapped hole for the grease nipple to screw into has been left open to the elements, there will be all sorts of grit and grime that will have entered the hole. Simply screwing a grease nipple into it and pumping it full of grease is only going to push all of that grit into the bearing cups and cause the premature failure of that UJ. However, as you point out blackwolf, I don't see why they would require the whole propshaft to be replaced, when it's really only the UJ in question that would need replaced. Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
18th Sep 2014 12:55pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
After a few days in Normandy a 10hr and nearly 500 miles drive through France, Belgium and into Holland to get to Arnhem for the weekend
Behaving its self and not missed a beat the whole journey It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
19th Sep 2014 6:54am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17480 |
I guess that it is allowing for one of the missing nipples to be the one for the splined joint on the shaft itself. |
19th Sep 2014 8:33am |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 |
The splined joints on the props hafts on my 110 don't have nipples and no holes provided for them either ...
Will ask them about it when I pick it up on Monday from the dealer in Penang. They've had if for almost 4 weeks to replace the clutch slave cylinder ... |
19th Sep 2014 10:36am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Finished stripping/cleaning the rear brakes ,all in all, pistons still in new condition,(12 month old )although the retaining pins had started to corrode,a quick spin in the drill wi some wire wool and Autosol cleaned them up nice,then found 3/4 of a tin of Dynax S-50 (oily wax)so that went in the chassis ,also found a leak which appears to be power steering related which is brilliant and really made my day .........................ARGHHH! Pov.spec,ftw. 2006, 110,TD5.
19th Sep 2014 11:13am |
rtm89 Member Since: 14 May 2013 Location: North Yorkshire Posts: 256 |
I brought mine in for that last time to work today.
Very happy 3 months in my second Firenze red XS Hardtop. Now into my new Corris grey XS hardtop for the next 3 months. Love my job!! |
19th Sep 2014 11:15am |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
I ventured into Peterborough first thing in mine to pick up an iPhone 6...
Click image to enlarge Almost as purdy as my 90... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] Last edited by Venomator on 19th Sep 2014 2:59pm. Edited 1 time in total |
19th Sep 2014 2:03pm |
White ones are for girls
19th Sep 2014 2:54pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
and all iphones are for sheep!
19th Sep 2014 3:10pm |
OldhamLandy Member Since: 17 Oct 2013 Location: somewhere Posts: 164 |
See the phone signal is up to the usual I Phone standard then 2016 Defender 90xs SW - Santorini Black with Silver Pack
2014 Defender 90xs SW - Corris Grey with Santorini Black Roof |
19th Sep 2014 3:11pm |
Bah |
19th Sep 2014 3:32pm |
So amusing... Actually those comments might be typical of have not lusting and equally applicable to, say, Landy owning as well... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
19th Sep 2014 4:38pm |
19th Sep 2014 4:59pm |
