Home > Maintenance & Modifications > Crystal headlights
Northernremedy
United Kingdom 2004 Defender 110 Td5 CSW Aintree Green
Crystal headlights
Hi team!
Fancy upgrading my headlights to the wipac crystals with decent bulbs (night breakers).
The issue I'm finding is lots of versions of the alleged same thing all with varying price tags, which are genuine?
Devon 4x4 very cheap http://www.devon4x4.com/index.php?page=sho...;Itemid=14
Paddock http://www.paddockspares.com/pm678-wipac-c...ralia.html
Alive http://www.alivetuning.com/alive-boutique/...uct_id=156
Anyway sure you get the picture, where should I buy from and what's genuine/what isn't? Thanks in advance gang Smile
Post #358044 15th Sep 2014 5:41pm
DOOFER
I got the wipac ones from paddocks. I love them.
Post #358047 15th Sep 2014 5:48pm
gilarion
Fitting wipac crystals with decent bulbs (night breakers) will give you marginally better light but to get the optimum lighting from this combination you will need to fit a replacement headlight harness taking power directly from the starter battery, that way you will get the proper wattage to the bulbs which will give you a white bright light rather than the slightly yellow light you will get without doing this modification
Have a look at this thread
http://www.defender2.net/forum/topic26097....light+loom
You can buy the harness quite cheaply off ebay links to this are in the above thread
Post #358050 15th Sep 2014 5:58pm
Northernremedy
Hi,
Thanks for the replies! Is perhaps a simple solution to put the osrams in with the existing (good nick) quad optics? Or will the wiring harness again limit?
Thanks
Post #358052 15th Sep 2014 6:05pm
Grouse
I have done this on two of my vehicles -just replaced with Wipac Crystals and the night breakers - I didn't upgrade the harness - there was still a massive improvement over standard - literally took 5 minutes to do. Avoid the cheap Crystals and make sure they are Wipac.
Post #358055 15th Sep 2014 6:16pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I'm with Grouse on this, Wipac crystals + nightbreakers + a little bling Thumbs Up
I make a few of these up and pop them on eBay to help fund bits and pieces for the Landy. I get my Crystals from JGS 4x4. At £39 a pair I'm not sure they are the cheapest around but they provide a good service. The Devon headlights look identical and are a good price although I'm guess that's for a single headlamp. If it's for a pair I'd bite their hand orf!
 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #358060 15th Sep 2014 6:42pm
Crystals with Philips Extreme bulbs on mine.
Post #358064 15th Sep 2014 7:01pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
At 20 quid from D4x4 and advertised as wipac units I don't think you can go wrong, as long as their postage isn't astronomical.
The alive ones come with bulbs as well but it doesn't specify a brand? How much is a set of nightbreakers?
Post #358070 15th Sep 2014 7:22pm
Northernremedy
Thanks team! That's one smart landy!
I bought some osrams on eBay for £14, so a set of wipacs from paddocks and we are laughing. Thanks all for help!
Post #358071 15th Sep 2014 7:23pm
Northernremedy
Hi team just to say thanks. The Devon ones are wipac and shipping is £6!!! Quite the bargain. Should have them all for some fettling at the weekend Razz
Post #358692 18th Sep 2014 3:20pm
Northernremedy
Installed! Awesome and easy, thanks Smile
Post #358952 19th Sep 2014 5:39pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Don't suppose you could take some pictures of one light with the night breakers and one with the standard bulb, would just like to get an idea of how much brighter they are.
Post #358959 19th Sep 2014 6:08pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Sorry if this is a daft question, but the 'halo' around the lights - is that just how the picture turned out or is that how it looks with the sidelights on? Looks very nice.
Also, would there be an improvement over std lamps? I've just had a look and mine are Wipac Quadoptic's fitted with Nightbreaker H4's. Would the Crystal's be any different?
Do you have a link to your eBay items?
[/quote]
Post #358996 20th Sep 2014 5:00am
