Home > Puma (Tdci) > Can this forum succeed where Land Rover have failed ?
bob neville
If you have read the post 'Clutch Death Rattle' you will be aware of the problem my 09 110 has.
In summary - new clutch fitted during service - now clutch engages at 23 mm off floor instead of 50 + mm - vehicle is undrivable.
Dealer has fitted another new clutch, two slave cylinders, new master cylinder, new pipes, adaptor supposed to resolve issue.
Clutch removed and fitted to another defender - result perfect !
LR tech support have no idea- in fact we think they are actually on extended tea break Laughing
Ralton in SA had a similar problem that was fixed by a setting change or adjustment - he has kindly contacted his dealer and is still waiting to hear back.
Grockle has eliminated the brake vacuum pump.
So, the dealer serviced the vehicle, adjusted the transfer box, applied the latest Qv68 patch and did some bodywork issues. When I got the vehicle back there was dirty engine oil dripping from the nearside underneath the area of the vacuum pump - hence my question on the other post about is it connected to the clutch in any way.
Does anybody have any idea what the problem could be ?
Stupid ideas I have include transfer box (eliminated so far by dealer), ecu setting, something to do with the anti stall ?
So, can we, as a forum solve the problem before Land Rover ?
Maybe I should start some form of sweepstake as to what the problem is ?
Any thoughts greatly received Thumbs Up
Bob
Post #35793 7th Jul 2010 6:50pm
mse
Well there is not clutch adjustment so nothing there
Nothing in the ECU would impact changing, infact i wouldnt say anything in the ECU would have any impact on operation on a puma
So there are two options - Gearbox or engine.
A quick gearbox swop will show if its the engine Mike
Post #35806 7th Jul 2010 11:17pm
NoDo$h
Enough fluid in the clutch master cylinder?
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #35812 8th Jul 2010 12:05am
bob neville
Thanks Guys.
Fluid levels are OK, dealer has checked numerous times.
On the Td5 there was a box under the coolant bottle, lid held on by six screws with a switch attached. If the cover of this was removed it revealed a bar with some half lock nuts. This was used to adjust the clutch pedal position and the grab point. Does this exist on the puma - for some reason I can't nip out and check mine Laughing
Hope it is not the engine or gearbox - they were fine and would hate to have them replaced.
Bob
Post #35823 8th Jul 2010 8:17am
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Re the clutch take up/adjustment, years ago pressure plates could be adjusted but since the advent of the diaphram clutch its no longer an option. Soething very odd if its ok in another vehicle. Can the peddle stroke be adjusted in Puma,s. Good luck I hope you get to the bottom of your problems.
Allan
Post #35824 8th Jul 2010 8:33am
Allan
Hi again Bob,
I've just checked the Puma workshop manual and yes the pedal travel is adjustable. The clutch pedal travel should be set at 135mm in total. The base of the pedal should be 140mm measured in a straight line to the floor of the vehicle. Regarding the ECU involvement, there is a sensor fitted to the clutch master cylinder and a peak torque limiter fitted to the slave cylinder that limits hydraulic fluid flow, if, for instance, your foot slips from the pedal when wet. This is to reduce possible damage to the drive train, may be worth a question to the dealer if this could be the cause, just a stab in the dark but who knows. Good luck.
Allan
Post #35832 8th Jul 2010 9:30am
bob neville
Thanks Allan Thumbs Up
Phoning the dealer shortly.
Bob
Post #35833 8th Jul 2010 9:51am
bob neville
Dealer has had to get some special equipment in to 'pressure bleed' the clutch as advised by LR Shocked
Bet it does not work Laughing
Bob
Post #35911 9th Jul 2010 11:28am
bob neville
Didn't work Big Cry
LR engineers will be at the dealer on Monday.
Bob
Post #35920 9th Jul 2010 3:45pm
Allan
Good luck on Monday, I would get pi..ed over the weekend and not think about it. This is what my wife advised me to do and I will listen to her direction because my clutch still has a death rattle and I wish to thump the dealer.
Something needs sorting with this Ford lump of crap under my very good Land Rover. What a great vehicle if they had moded the TD5 or detuned the D3 engine. You can tell its the end of the Defender and they don't care. We are the poor cousens.
Allan
Post #35925 9th Jul 2010 5:04pm
mse
Keep your chins up - they do work they can be great. Thumbs Up Mike
Post #35927 9th Jul 2010 5:40pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Bob,
I scanned the 'clutch death rattle' post but couldn't see the exact symptoms described. If your clutch has been fitted to another Defender and is "fine" then it clearly isn't the fault.
Mine went in a couple of years ago with a "chatter" or "clonk" from the transmission. It turned out to be a badly adjusted handbrake.
Symptoms were (when warm) coasting to a stop (in gear, or out; clutch in, or out) it would sound like the whole transmission was shaking itself to bits (which it was) at a frequency of around 2Hz. It sounded terrible (clonk a clonk a clonk) and I could feel the vibration.
Solution was to adjust the handbrake. The dealer had to do it a couple of times and it stayed away for a year or so. I've just noticed it starting to do it again so I'm going to ditch the drum brake in favour of an X-brake.
It may well be nothing like what you're describing but if you're fishing for ideas...
HTH
Alan One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #36433 16th Jul 2010 4:07pm
bob neville
Alan
My symptoms were the change from first to second and second to third were very notchy and there was a slight rattle.
The new clutch was fine, but the bite point was virtually on the floor.
They put the clutch into another vehicle to prove to themselves that it was OK.
The eventual solution was hinted at in my second post on this topic. The LR engineer came down from Solihull and the problem was an adjustment to the clutch mechanism/adjusting rods. These are supposed to be set for life from the factory.
So now, believe it or not, the gear change is excellent - it only cost LR two clutches, two master cylinders, two slave cylinders, pipes and who knows what else to sort out a job that, in the end, took 30 minutes !
This is now the third clutch that I have had fitted and it is far superior to the others. I also had the transfer box adjusted plus the dealer did some work on the selectors.
Once it has bedded in I hope it will be even better !
Bob
Post #36437 16th Jul 2010 4:42pm
Allan
Hi again Bob, just a couple of questions re your clutch disfunction. 1; was noise/rattle evident at engine start -stop if clutch dis engaged? 2. If clutch did display these symptoms, were they evident when clutch was engaged? 3 Did transmission display a chattering noise in 1st gear at low rpm, especialy when hot and under load? 4 Was a noise evident when vehicle was ideling in neut. and clutch engaged and dis engaged, . Any constructive input would help.
Allan
Post #36439 16th Jul 2010 5:18pm
