![]() | Home > Td5 > ERG Removal |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5805 ![]() ![]() |
Yes I think will be ok. The exhaust is effectively blocked off as it would be with kit, just further along the system.
Andy Ps Do yourself a favour. Stop buying Britpart stuff, it is poo |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
As long as there is no leak of exhaust gasses it should be ok indefinitely.
I removed the whole of the heat exchanger eventually and in so doing fixed a slow coolant leak which had eluded me for about 2 years! I second what Andy says about Britpart. |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
I am learning about Britpart stuff !
I originally thought it was good but the wheel carrier (swing away) is a bit poo ! Cheap and half the price of the others but still poo. The ERG valve issue is not Britpart it was more the fact that the bolt was seized and I f'k it ! Ah the joy of landrover ownership ! ! ! Cheers for advice ![]() Duncan |
How do you take the rest of the heat exchanger off ? Do I need to block up either end if I don't ?
Cheers again Duncan |
I had already blanked the exhaust at the manifold, so only the coolant pipes were still connected. One of these comes from somewhere round the back of the block under the inlet manifold (fuel cooler or something, I forget), the other to the header. I simply replaced both of these with a new hose straight to the header, though I did need a reducer since 1 pipe is much bigger than the other.
This is on a Disco, not a Defender, but the principle is the same. I only did it because I like simplicity and don't like having bits that aren't needed bolted on. It was an unexpected bonus that it fixed the slow leak (which I had always attributed to the threaded core plug under the exhaust manifold). |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
I left my heat exchanger in place. My thinking was/is a bit more cooling (possibly) can't be a bad thing. It wasn't me!
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6127 ![]() ![]() ![]() |
Regarding the manifold end cap bolts..... heat works, so, go for a nice 30 miles drive, then get home and try to undo them... you might find the heat from the exhaust itself is enough to shift it... also plenty of penetrating oil beforehand (might smoke a bit when you're driving mind)
Cheers Jim will try that although I might have rounded it off now will all the "trying" !
Duncan |
