Home > Puma (Tdci) > Why my turbo leaked
Page 2 of 3 <123>
HMARR
Ok thanks Thumbs Up
Post #343381 7th Jul 2014 9:18am
landy andy
Is there any alternative option to a machine shop skim?
Mine blowing and have already fitted the Nak exhaust gasket, but it's gone again. I have a holiday planned and the land rover show to attend, so am really really tight on time and guess a machine shop will require turbo for a couple of days.
Any thoughts?
Andy
Post #357345 12th Sep 2014 5:21am
bell-auto-services
You could take the manifold off and so it manually old school with a flat file but it's a boring task. You possibily could also but a very fine layer or dealer on the gasket to help it re seal.
How is your air intake system ? Restricted ?or your intercooler and inlet manifold as well as exhaust and cat come to think of it.
Pete.
Post #357349 12th Sep 2014 6:10am
landy andy
May have to go old school then.
I'm running safari snork, uprated intercooler, and standard exhaust. I am thinking that a large part of the problem is the cat restricting flow, any thoughts?
Am I correct in thinking that once machined flat/filed sweated sworn removed nuckles flat, that it will ok for ever after? Like the td5 manifolds were?
I don't mind the fact it's warped, it's just the bloody timing of it Big Cry Big Cry
Andy
Post #357358 12th Sep 2014 7:13am
AndrewS
The casting is quite soft, it doesn't take long by hand with a file.
Post #357367 12th Sep 2014 8:02am
landy andy
Great, fantastic. Will get it done this weekend, if I can source new gasket in time.
Thank you for letting me know Bow down Bow down Thumbs Up
Andy
Post #357371 12th Sep 2014 8:42am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
What about some of this?
http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802627420161 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #357375 12th Sep 2014 8:46am
landy andy
Don't think it goes high enough heat. Exhaust manifold would get to 500-600 degrees + I would guess.
Post #357387 12th Sep 2014 9:13am
K9F
Defintely! A Cat strangles the engine. It 'was' the cheapest upgrade with immediate noticeable performance enhancement you could carry out for the money. Turbo spools up quicker giving you accelerated toque at lower rpm. Well worth the time involved to do in my opinion. Nevertheless for current legislation at MOT time a visual check is carried out to ensure a CAT is present (or the check should be carried out but often overlooked).
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #357390 12th Sep 2014 9:32am
jomara
Oops!!! Looking through my big list of potions we have used on the racers I have this:
http://www.designengineering.com/press/spa...ge-sealant
You can get it from Demon Thiefs!!
http://www.demon-tweeks.co.uk/motorsport/w...eliminator 2014 110 2.2TDCi XS Station wagon
Post #357391 12th Sep 2014 9:33am
landy andy
Can't decide between. Smash out internals of existing cat, or get a decat down pipe. Keeping original incase. I'm concerned that rules may change to test if cat is working not just visible. Although my mot test man said when questioned "if it's remapped, it's not a standard engine, so cat not required".
Andy
Post #357392 12th Sep 2014 9:41am
landy andy
Demon tweaks stuff looks good Thumbs Up
Thanks may order one
Post #357393 12th Sep 2014 9:43am
landy andy
Demon tweaks stuff ordered. £14 for the stuff £20 for sat delivery. Crying or Very sad
Post #357395 12th Sep 2014 9:54am
K9F
landy andy wrote:
Although my mot test man said when questioned "if it's remapped, it's not a standard engine, so cat not required". Andy
Rolling with laughter Not the brightest button in the basket then? There are obviously several 'ways to a means' with this. I sold my Cat ages ago and the rules then subsequently changed so I had to 'adapt' as I had a stainless system using the decat pipe.
Personally for the very reasons you stated I would retain the original Cat in one piece and find another route should you wish to proceed. By the sound of it with your tester you may well just fit a decat perhaps? Down to Personal Choice...... If you go through life with your head in the sand....all people will see is an ar5e!!
Post #357398 12th Sep 2014 10:06am
jomara
That look the mutts Mal Thumbs Up
Glad you got something Andy, I have a favourites tab full of potions and lotions we have used over the years doing jobs on the comp safari cars, its amazing how the standard items from Halfrauds don't hold up to the rigours of racing and end up costing you a finish!! 2014 110 2.2TDCi XS Station wagon
Post #357409 12th Sep 2014 10:38am
Page 2 of 3 <123>
