![]() | Home > Puma (Tdci) > Why my turbo leaked |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Could this be described as fraud ![]() ![]() ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
No. As it is a cat if I'm correct. And very very nice idea too.
It is indeed a cat and for simplicity it is fitted on my Puma in exactly the same place as a TD5....Zero CPSI, 100 CPSI, 200 CPSI...... AndrewS it can be whatever you wish it to be when deciding on the internal matrix. That's the beauty of manufacturing your own.
![]() THIS could possibly be categorised as fraud?...... ![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
De-catting my 90 is very easy. Only I have to do it often.
![]() ![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
![]() ![]() ![]() ![]() ![]() You are my myth ![]() ![]() IID Pro MV License |
Turbo off and what a faff, clearly an engine not designed for the engine bay
![]() ![]() ![]() Click image to enlarge I'm sure it was more triangle when installed. Andy |
