Home > In Car Electronics > Radio stopped!!!
lrshoot
England 2006 Defender 110 Td5 DCPU Bonatti Grey
Radio stopped!!!
Hi all, on the way home the other day my radio/cd player stopped working, the display is still on but no sound. I've checked the plugs and the fuse in the back of the unit and the fuse in the main fuse box and it all seems okay. The unit is the standard factory fit. Visteon radio/cd, my landy is a Defender TD5 double cab on a 06 plate.
Any help, suggestions would be very welcome thanks
Post #356528 8th Sep 2014 5:15pm
K9F
Output transistors perhaps? If you've display and no sound easiest thing perhaps if you have one or can get a loaner is to try another head unit maybe? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #356531 8th Sep 2014 5:28pm
lrshoot
As I don't have access to spare or loaner head unit, it looks like I need to get the output transistors looked at as you suggested. Thanks K9F
Post #356627 8th Sep 2014 10:09pm
Be careful of cost though, might be more worth your while and cheaper to get another.
Post #356637 8th Sep 2014 10:38pm
lrshoot
Can't be that expensive to get it checked out, can it?
thanks, custom 90 steve
Post #356698 9th Sep 2014 7:58am
K9F
Any decent ICE retailer should just be able to plug it in and check it if you remove it and take it in. Shouldn't need a strip down and detailed diagnosis to achieve this.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #356726 9th Sep 2014 11:19am
ZeDefender
Don't forget to take the code key with you... Tell someone you love them today because life is short.
Post #356772 9th Sep 2014 2:28pm
lrshoot
Thanks guys,
Just had another look/play/fiddle with the radio and as I was removing the brown plug the radio started to play!! (I hadn't turned it off) but when I pushed it back in until it clicked it went off again, I tried it several times with the same result, strange!! I'll see if I can get it looked at tomorrow
Post #356784 9th Sep 2014 3:39pm
Iirc that's the power supply plug, sounds like it wasn't secure.
Post #356785 9th Sep 2014 3:42pm
Oops, my mistake I was wrong:
All the same I think a the plug was loose which has caused the issue.
Above is for a a Puma however.
Post #356786 9th Sep 2014 3:44pm
lrshoot
The plugs for the puma look the same as mine, both plugs are a good tight fit, it was only when the brown plug was part way out that the radio started playing, but as I pushed it back in it stopped, I tried it several times, part way out it plays push it back in and it stops, every time it clicks when it's pushed back in so it's locked in place.
Post #356797 9th Sep 2014 4:42pm
lrshoot
UPDATE!!
Had the unit checked out today and it turned out to be the right rear + speaker wiring that was at fault, as I don't have any speakers in the back, the wires were disconnected, and all back to normal Very Happy
Thanks to all that replied
Post #357094 10th Sep 2014 6:56pm
Could well have been a short?
Post #357124 10th Sep 2014 8:36pm
lrshoot
Yes, I think the guy descibed it as a intermittent short, going over all bumps an pot holes that we encounter everyday, and the rear speaker wires (where ever they are hidden ) were not secure!! so all sorted now, and one happy bunnie!!!!!!!
Thanks
Post #357131 10th Sep 2014 9:15pm
Glad it's sorted, not good though! Possible fire hazard...
Post #357133 10th Sep 2014 9:20pm
