![]() | Home > Puma (Tdci) > SD-NAS Roll Cage+Recaro's? |
Don't fit in my 50th
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Thanks.
I got a 50th too but believe the bar is different to a 110NAS set up. The thick padding doesn't help either. I want to fit my 110 with a SD cage but consider fitting the seats at a later stage. m |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
You could talk to Protection and Performance about a cage to fit your needs. They specifically tailored a bulkhead removal bar for SVX/Recaro so I'm confident they would understand the issue. www.td5.org
Thanks for your inputs so far!
Being in AUS the easiest would be to get a SD. I probably go for it and alter later down the track if I have to.m |
jwb Member Since: 30 Oct 2012 Location: Los Angeles Posts: 27 ![]() ![]() |
I have a puma 110 with SD L172 and SVX Recaros. They fit as long as you use the outer seat rail spacers that come with the recaros. I also swapped left and right seats so the recline knob doesn't hit the B hoop. Still, depending on how much leg room you or the passenger need, the upper shoulder bolster could rub on the B hoop. I'm 6ft and don't have an issue, but a few inches taller and I'd have to use additional spacers to tilt them inward a little more. I have a set of the rubber hoop pads but have not tried to install them yet, but assume I'll need to notch them near the shoulder bolsters. I absolutely love the recaros.
Cheers |
Hi jwb, Thanks for that:) It is the answer I waited for! m
