Home > Puma (Tdci) > SD-NAS Roll Cage+Recaro's?
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
I was wondering if someone has the SVX Recaro's seats and a SD NAS roll cage with the internal hoop fitted? Does it all fit together? Thanks m
Post #356189 7th Sep 2014 4:27am
Don't fit in my 50th
Post #356190 7th Sep 2014 5:30am
100inch
Thanks.
I got a 50th too but believe the bar is different to a 110NAS set up. The thick padding doesn't help either. I want to fit my 110 with a SD cage but consider fitting the seats at a later stage. m
Post #356192 7th Sep 2014 5:40am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
You could talk to Protection and Performance about a cage to fit your needs. They specifically tailored a bulkhead removal bar for SVX/Recaro so I'm confident they would understand the issue. www.td5.org
Post #356219 7th Sep 2014 8:49am
100inch
Thanks for your inputs so far!
Being in AUS the easiest would be to get a SD. I probably go for it and alter later down the track if I have to.m
Post #356223 7th Sep 2014 9:09am
jwb
United States
yes, with some tweaking
I have a puma 110 with SD L172 and SVX Recaros. They fit as long as you use the outer seat rail spacers that come with the recaros. I also swapped left and right seats so the recline knob doesn't hit the B hoop. Still, depending on how much leg room you or the passenger need, the upper shoulder bolster could rub on the B hoop. I'm 6ft and don't have an issue, but a few inches taller and I'd have to use additional spacers to tilt them inward a little more. I have a set of the rubber hoop pads but have not tried to install them yet, but assume I'll need to notch them near the shoulder bolsters. I absolutely love the recaros.
Post #356420 8th Sep 2014 12:51am
100inch
Hi jwb, Thanks for that:) It is the answer I waited for! m
Post #356421 8th Sep 2014 1:47am
