Home > Maintenance & Modifications > Grille options |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 520 |
bloody hell £740
5th Sep 2014 2:37pm |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 411 |
i have a kbx grill in which i chopped out all the centre bars, it looks nice, doesnt break the bank and also makes it look more like the iconic nene 90's
17th Sep 2014 12:50pm |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 |
I'm still undecided myself. I have a silver 90 without a/c and can't choose between the nakatanenga heritage or kbx, both in black
17th Sep 2014 6:28pm |
redzob Member Since: 16 Jul 2014 Location: St. Peter Port Posts: 137 |
@ Ronin - Looks very nice. I'm considering the Lazerlamps grille and wondered how easy the wiring was to do for a non-electrician?
Thanks in advance. Defender Puma 2.2 XS 90 Vespa GTS 300 Way too many racing bikes. |
20th Oct 2014 6:53am |
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 269 |
It is now possible to purchase the Zumsport grille without the lazer lights
20th Oct 2014 8:21am |
Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 |
I'm no auto-electrician, but I took my time and found the whole process simple and enjoyable. There is a really helpful diagram on this website (I think it was originally produced by 'The Boy') which I used because I wanted to do a proper job and to use the standard LR auxillary light dash switch (rather than have the LEDs illuminate with the headlight flash*). I bought all the bits and pieces I needed (including the relay) from these chaps: http://www.autoelectricsupplies.co.uk/ and it was far cheaper than cobbling it all together from Halfrauds. All of the wiring I installed runs through convoluted tubing and the whole shebang is adequately fused. Devon4x4 also sell a Lazer wiring kit for £50ish which makes the whole process very simple indeed, just in case you're still feeling nervous. As long as you can give yourself half a day or so and can handle basic DIY, I'd recommend that you give it a go. Joel * I believe that this is illegal, but I already have a headlight flash-triggered relay secured in the battery box and will substitute this before my first MOT (in July 2016...). |
20th Oct 2014 6:27pm |
@Ronin - brilliant. Many thanks for your help. Defender Puma 2.2 XS 90
20th Oct 2014 6:31pm |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 717 |
Redzob, first dibs on your heritage grille if you're swapping it please! Thanks, Andy
31st Oct 2014 9:39pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
The Zunsport range of grilles are now available to buy at www.FCX.co.uk
The Lazer light edition is very popular ! |
1st Nov 2014 7:06am |
Wheel Member Since: 28 May 2014 Location: Essex Posts: 233 |
Hi All,
I like the original look and would like a gloss black original type grille ala the one fitted to the "Black Pack" but on enquiry they want £400 all in for the 3 bits. Does anyone know if these are available elsewhere, i.e Britpart etc as it seems i can get the centre grille in gloss although theres some doubt it'll fit a 2007 > model but i can't seem to get the headlight surrounds ? At the moment i'm looking at getting some new matt ones and having them sprayed Santorini black as i want to keep my XS grey ones to maybe put back on if/when i sell it but i'm not sure just a grille will fit or do i need the extended for A/C grill complete ? I was thinking (hoping) the plastic grille part could just be replaced ? Does anyone have experience of doing this or similar please ? Thanks, Mark |
2nd Nov 2014 9:09am |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
sell your grey ones on eBay (or keep them)
buy some standard grilles off eBay or any parts supplier and then sand, prime, paint and lacquer them. I've just got standard black ones on mine but been meaning to get around to painting them properly in gloss black. Lacquer is important otherwise stone chips take the paint off and it looks rubbish. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
2nd Nov 2014 2:52pm |
