Home > Puma (Tdci) > Cold weather & tdci doors
MT
Not that I'm trying to be pessimistic but I'm aware winter is never too far away and I'm about to replace the doors on my 110 (td5). I'm wondering if all you tdci owners experience the same problems in the cold weather with the central locking not working and the doors not closing? I think I'm talking myself into buying tdci doors...
Post #354864 31st Aug 2014 11:59pm
jimbob7
Only if not given basic maintanance,Clean out the locks with clutch/brake/contact cleaner DO NOT USE WD OR ANY OTHER "RELEASE AGENT".Then use a suitable lock grease like graphite (which is a dry powder),I use lithium/white grease inna aerosol, coz it helps keep the sh*t out,DO NOT USE WD OR ANY OTHER "RELEASE AGENT".Defender locks are very exposed to the weather and road cr*p so suffer more than most,WD Censored lubricates the lock for about 10 seconds then starts attracting more dirt.Also clean the door rubbers with mild soap then treat them with a quality trim protectant, Gummi Pfledge is top stuff,this does 2 things protects the rubber from rotting and stops the rubber absorbing moisture which will then prevent your doors from freezing shut.
http://www.ebay.co.uk/itm/EINSZETT-GUMMI-P...0397740572 Pov.spec,ftw. 2006, 110,TD5.
Post #354872 1st Sep 2014 2:17am
and don't forget to use silicone spray on the rubbers so that the doors don't freeze shut
Post #354892 1st Sep 2014 8:33am
Venomator
Any particular make/kind of silicone spray BPMan?
Thanks,
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #354909 1st Sep 2014 9:38am
Any, I've used machine mart spray and jolly halfords Thumbs Up
Post #354914 1st Sep 2014 10:38am
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Last winter was pretty mild and my doors froze shut a couple of times. Aerosol white grease and some silicone rubber lubricant did the trick!
Post #354927 1st Sep 2014 12:44pm
shaggydog
Just make sure it isn't a scented Silicone Spray or is a smell you can live with.
I bought mine in a hurry as it was on offer and then sprayed one half of a door rubber with the most acrid sickly sweet bubblegum smell I have ever smelt. Lasted for weeks Big Cry
Post #354932 1st Sep 2014 1:10pm
mk1collector
DONT use silicon! If your defender ever needs paintwork it will make a mess.
Post #354976 1st Sep 2014 7:34pm
Dieselhead
Vasilene I was told once works well on the rubbers Shocked Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #354979 1st Sep 2014 7:56pm
