![]() | Home > Puma (Tdci) > Cold weather & tdci doors |
Only if not given basic maintanance,Clean out the locks with clutch/brake/contact cleaner DO NOT USE WD OR ANY OTHER "RELEASE AGENT".Then use a suitable lock grease like graphite (which is a dry powder),I use lithium/white grease inna aerosol, coz it helps keep the sh*t out,DO NOT USE WD OR ANY OTHER "RELEASE AGENT".Defender locks are very exposed to the weather and road cr*p so suffer more than most,WD
![]() http://www.ebay.co.uk/itm/EINSZETT-GUMMI-P...0397740572 Pov.spec,ftw. 2006, 110,TD5. |
and don't forget to use silicone spray on the rubbers so that the doors don't freeze shut
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Any particular make/kind of silicone spray BPMan? Thanks, Rog... ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Any, I've used machine mart spray and jolly halfords
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 ![]() ![]() |
Last winter was pretty mild and my doors froze shut a couple of times. Aerosol white grease and some silicone rubber lubricant did the trick!
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Just make sure it isn't a scented Silicone Spray or is a smell you can live with.
I bought mine in a hurry as it was on offer and then sprayed one half of a door rubber with the most acrid sickly sweet bubblegum smell I have ever smelt. Lasted for weeks ![]() |
DONT use silicon! If your defender ever needs paintwork it will make a mess.
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Vasilene I was told once works well on the rubbers
![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
