Home > Puma (Tdci) > dipped beam not working...
Eduardo
Hi there!
Probably asked for many times but I cant found it Embarassed Embarassed
I dont have dipped ligths. Position ligths, and main beam working OK. but no way to have dipped ligths Sad
I check the main light switch and seems to be OK, also I swap the realys and nothing. Also I test the bulbs and nothing
Any idea? Eduardo
Post #354321 29th Aug 2014 5:32am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
It's most likely your light switch in the steering column - the contacts are easy to see and test with the plastic shroud removed. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #354322 29th Aug 2014 5:42am
Eduardo
Thanks SiWhite
Just a quick question: When I turn the ligth switch in the dipped ligth position the position ligths turned on but not the dipped ligth.
Are connected to other circuit inside the switch?
I check the connections of the main ligth switch wires: 3 --> red-blue-brown. Brown is always live. In dip position red going live and in main beam position both, red and blue going live. Its that OK?
Cheers! Eduardo
Post #354323 29th Aug 2014 5:53am
VeeTee
Netherlands
Yes, seems right. Try to connect the wires outside the switch and see if there is light Very Happy
Most of the time the switch looks right but the plastic piece where the contacts live melt and then the switch is faulty.
A useful modification is to use relays to switch the lights, so there is less currrent going through the contacts in the switch.
See this topic over here. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #354328 29th Aug 2014 6:59am
Eduardo
I will do that.
I change the ligth switch around 3 month ago Evil or Very Mad Usually last 2 years amd burned up.
Thanks Eduardo
Post #354372 29th Aug 2014 12:05pm
ZeDefender
More info from various members who did the mod...
http://www.defender2.net/forum/topic26097....light+loom
Some used the Dutch harness (easy but expensive) and some made their own. Anything is a good idea over stock Rolling Eyes Tell someone you love them today because life is short.
Post #354380 29th Aug 2014 1:07pm
VeeTee
Netherlands
Eduardo wrote:
I will do that.
Thanks
Did you do a lot of towing lately? The current to the trailer lights is an additional load for the switch.
The relay loom is really a first class modification! Very Happy Cheers, Vincent
MySite
Post #354399 29th Aug 2014 4:49pm
Eduardo
Nop,
No towing in the last months Sad Eduardo
Post #354407 29th Aug 2014 5:35pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Change the bulbs 1st
I had a similar issue and it was both dipped bulb elements blew on the same day.
2 new bulbs later and all was OK..... BM52
Post #354423 29th Aug 2014 6:55pm
Eduardo
Both bulb were tested and are OK Sad Eduardo
Post #354425 29th Aug 2014 6:58pm
munch90
maybe worth checking the dip/main indicator switch as well
the light switch ( the short one on the column ) feeds the main/dip indicator switch ( the long one ) maybe contact on there burnt
can't be the light switch as you would lose dip and main so must be down stream of the light switch
light switch ( short one ) feeds sidelights (first postion )direct off switch , dip and main ( second position ) on switch feed to the main/dip indicator switch then to lights
Post #354500 29th Aug 2014 11:00pm
Eduardo
New ligth switch changed and no improvement Big Cry
Relay already checked and it is OK (at least for the main beam)
Bulbs also has been checked and are OK
As Munch said, probably the dip/main indicator switch is burned Sad .
Any idea of how to check it and how its work?
Just one question...
It is necessary remove the streering wheel to take out it?
Cheers Eduardo
Post #355271 3rd Sep 2014 2:34am
munch90
yes the dip/main/ indicator switch is mounted on metal plate that fits over the steering column , if you take the switch off the plate I think your find springs and bits drop out and you got the indicator cancel ring round the column anyway .
but you could just plug the new switch in first just to check rather then fit it straight away
you say you checked the relay , what relay ? as far as I know there is no relay or are you talking about dim dip control unit ? or have you fitted the relay upgrade loom ?
Post #355277 3rd Sep 2014 6:35am
There is a relay - it is ignition energised and has the function of shutting off the headlights if the engine is switshed off.
If it malfunctions you will have neither dip nor main beams.
Post #355287 3rd Sep 2014 8:26am
