Home > Wheels & Tyres > Advice
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
Advice
Is anyone running 275/60/20 or 275/55/20 cooper LTZ not sure what size to go for. I have a set of 285/50/20 going to try them any advice would be helpful thanks
Post #354169 28th Aug 2014 10:44am
K9F
Do you have a lift? Fitting 20" with a profile of 60 you may find you'll need it.Searching through some of the threads your profile of 60 seems big. Have you thought about the speedo and gearing implications?
Have a play with these:-
http://api.viglink.com/api/click?format=go...%3C%2FB%3E
Effect on speedo: At least you shouldn't get caught speeding as it'll under read by about 10%
http://tire-size-conversion.com/speedometer-calibration/ If you go through life with your head in the sand....all people will see is an ar5e!!
Post #354177 28th Aug 2014 11:19am
chris d3
2mph out on the bigger the same 255/55 need to no if they rub what the ride is like
Post #354195 28th Aug 2014 12:52pm
K9F
PM Killer90 he used to run 20" wheels. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #354197 28th Aug 2014 1:08pm
