![]() | Home > Maintenance & Modifications > RDX LED relay it does what it says on the tin!! |
udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124 ![]() ![]() |
You can fit a separate, adjustable relay just for the trailer. Combined with an adjustable LED flasher relay, this will allow any combination of LEDs /Bulbs, and allow the correct dash indication
Matt http://www.duriteparts.com/durite_0-506-12...ight_relay Real trucks don't have spark plugs |
90XS Member Since: 01 Aug 2014 Location: Shropshire Posts: 76 ![]() ![]() ![]() |
How have other people found the flash rate with this relay? I started off with the mobile centre one but it flashed far to fast. Bolt on bits one arrived today, installed and set up as per instructions, but the indicators do seem to flash rather fast. I'm getting approx. 100 flashes per minute. Whilst this is within the range come MOT time, it does seem a lot faster than most other vehicles. Any ideas welcomed!
with the bolt on bits one I found the flash rate looked a bit slow , same still within mot rate but didn't look right took it out , never even used it just tried it and went back to one I had used for years that looked better
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Wonder if it's slightly variable dependant on vehicle?
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
It's possibly related to component tolerances inside the relay. It would be interesting if 2 different owners could swap relays to test.
I plan to purchase one of these in the next few months (along with LED indicators), so I'll see if it's possible to make a modification to the circuit components to change the flash rate. I've know idea what the circuit looks like at the moment, but will investigate once I have one in my hands. http://defender90xs.blogspot.co.uk/ |
If you know your electronics well unlike many of us (myself included) pictures would be good if you can.
As with every job I do, I'll write it up with pictures for my blog
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
I have a wipac one. On its own the flash rate is the same as standard, with a trailer attached it speeds up. I assume this is the prevent the electronics in the relay getting too hot? 2002 90 Td5 Station Wagon
I tried a Mobilecentre one in my previous Puma which had a set of RDX LED's but the flash rate was only just within the 60 FPM rate plus the trailer tell tale was on all the time so I went back to the RDX with its slightly quicker flash and adjustable tell tale. All now transferred to the new motor. Steve.
