![]() | Home > Puma (Tdci) > Diff Oil Seal (pinion) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5850 ![]() ![]() |
I grease mine
Andy |
silicone sealer does make seals slide in easier and you got the added bonus of sealer round the outside just in case , BUT only use a thin smear round outside and make sure none gets on the sealing lip as it will make it leak
Montblanc Member Since: 10 Feb 2013 Location: Les Houches, Chamonix Valley Posts: 14 ![]() ![]() ![]() |
Looks like I need to change the rear diff pinion oil seal
![]() Does anybody know the correct part number for a 110 puma SW (Registered Nov 2007). I see two part numbers listed for the rover axle. Is the any complication regarding changing the seal with the axle/diff in situe? My puma workshop manual doesn't mention the oils seal replacement and my older 110 manual only describes the oil seal replacement only with the pinion removed as part of a complete diff over-hall. Neil |
