![]() | Home > Technical > Live issues on M6 now home |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
Check the speedo plug/loom is in place and in clean contact near the transfer box. I had the same. Puma 110" SW
Can't help.
You should have said you were on you way up to aberdeen it would have been nice to meet a member and have a look at you rig |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
I am sure it is not this, but just in case!
http://forums.lr4x4.com/index.php?showtopic=57697 Andy |
Home now
![]() Found a bit more out, it only happens on full throttle when you back off a bit, for instance when a slower vehicle enters the fast lane and one shuts off, the engine dies, speed rapidly reduces (not nice as you can imagine) then when the vehicle slows between 45mph and 60mph all of a sudden the power is back. I'm thinking lack of fuel fuel pump cant cope with maximum demand type thing. I will check out MK's comments ![]() BigRuss ![]() ![]() landy andy ![]() ![]() ![]() |
I forgot to mention that the speedometer also went crazy (up and down) when I had the problem. Puma 110" SW
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Hi Andrew, my 110 did the same thing once. The dealer blamed the EGR and replaced it, never had the problem since.
Cheers, Tim |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Andrew you have a cool gadget kicking about to read the faults, blow the cob webs of it and give it whirl
![]() ![]() Pete |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i had very similare, got a call from the dealer to say they had spent 10 hours on it and found out the course (it had been in before but they could not figger it out) the reason was overheating due to mud in the radiator and before they "fix'd" it they wanted £890.00
Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88 ![]() ![]() ![]() |
Hi guys could do with your help I have the same problem as Andrew had only I,m in France!!! Landie will go about 120 miles and then no power down to 50mph and no more so I pull up and leave ten mins and of we go again fine for another 100 ish miles. I,v just had new filters I check the fuel cap ,or taken it off a couple of times to check for any vacum . I,v try with and without remap on! The only fault codes I am getting is to do with instrument cluster which makes sence but can anyone tell me which connections to play with pls .
![]() ![]() ex 1988 defender 90 ,td ex 1970 series III |
try to look out for the temp gauge going above half way that was the first thing that i saw, then the loss of power, just an idea.
