Home > Technical > Live issues on M6 now home
AndrewS
Drove from home to Aberdeen yesterday, on our way back now belting down the M6..... well trying too. every now and then the 110 looses power the speed drops to about 50mph then gradually the power comes back and hey presto flat out again. Until a few more miles and the same thing happens. Its like running out of fuel.
No warning lights
No fault codes
Removed filler cap. No difference
Air filter is new and so is fuel filter.
I think its a fuel starvation issue.
Any ideas Question 130's have feeling's as well you know Smile
Post #35336 29th Jun 2010 7:12pm
MK
Check the speedo plug/loom is in place and in clean contact near the transfer box. I had the same. Puma 110" SW
Post #35340 29th Jun 2010 7:44pm
AndrewS
Thumbs Up 130's have feeling's as well you know Smile
Post #35346 29th Jun 2010 7:57pm
BigRuss
Can't help.
You should have said you were on you way up to aberdeen it would have been nice to meet a member and have a look at you rig
Post #35348 29th Jun 2010 8:35pm
landy andy
I am sure it is not this, but just in case!
http://forums.lr4x4.com/index.php?showtopic=57697
Andy
Post #35349 29th Jun 2010 8:36pm
AndrewS
Home now Thumbs Up Will be heading into the dealers asap.
Found a bit more out, it only happens on full throttle when you back off a bit, for instance when a slower vehicle enters the fast lane and one shuts off, the engine dies, speed rapidly reduces (not nice as you can imagine) then when the vehicle slows between 45mph and 60mph all of a sudden the power is back.
I'm thinking lack of fuel fuel pump cant cope with maximum demand type thing.
I will check out MK's comments Thumbs Up
BigRuss Thumbs Up will do next time Thumbs Up
landy andy Thumbs Up That issue is an air flow meter fault. Experienced it loads of times on the TD5, simple cheap fix. The air flow meter is located in the filter box un clip it unscrew it and replace, they are only a few quid to boot Thumbs Up 130's have feeling's as well you know Smile
Post #35358 29th Jun 2010 10:13pm
MK
I forgot to mention that the speedometer also went crazy (up and down) when I had the problem. Puma 110" SW
Post #35359 29th Jun 2010 10:18pm
Tim_NZ
Australia
Hi Andrew, my 110 did the same thing once. The dealer blamed the EGR and replaced it, never had the problem since.
Cheers,
Tim
Post #35362 30th Jun 2010 12:40am
bell-auto-services
Andrew you have a cool gadget kicking about to read the faults, blow the cob webs of it and give it whirl Whistle select read from ecu at the same time Smile
Pete
Post #35405 30th Jun 2010 9:35pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i had very similare, got a call from the dealer to say they had spent 10 hours on it and found out the course (it had been in before but they could not figger it out) the reason was overheating due to mud in the radiator and before they "fix'd" it they wanted £890.00 Shocked for the 10 hours it touch them to find it, well no money paid and i used my own garden hose, the only sign you may see is the temp guage going just past half way.
Post #35483 2nd Jul 2010 12:44pm
Robofarmer
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Hi guys could do with your help I have the same problem as Andrew had only I,m in France!!! Landie will go about 120 miles and then no power down to 50mph and no more so I pull up and leave ten mins and of we go again fine for another 100 ish miles. I,v just had new filters I check the fuel cap ,or taken it off a couple of times to check for any vacum . I,v try with and without remap on! The only fault codes I am getting is to do with instrument cluster which makes sence but can anyone tell me which connections to play with pls . Question Thumbs Up 2008 110 County utility
ex 1988 defender 90 ,td
ex 1970 series III
Post #37944 12th Aug 2010 6:05am
double cab happy
try to look out for the temp gauge going above half way that was the first thing that i saw, then the loss of power, just an idea.
Post #37976 12th Aug 2010 12:31pm
