![]() | Home > Maintenance & Modifications > RDX LED relay it does what it says on the tin!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
I've got the same no complaints.
![]() One tip though, adjust with the engine running not with just the ignition so that the voltage is higher. This way you get the quickest possible flash rate but with the trailer light off. If you do it with just the ignition on it'll seem right but when the motor is running the trailer light will start coming on. |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Just wish they did a 24volt version! I have the Mobilecentre one fitted at the moment and I don`t like the flash rate as it`s very slow. Also does not have the trailer light function which I want so will probably end up fitting an original Landrover flasher unit and some resistors.
Buccaneer Member Since: 11 May 2014 Location: London/Kabul Posts: 148 ![]() ![]() ![]() |
Sadly for us 50th's owners a total b*****d to fit as we have to remove shed loads of things and skin knuckles to get to where the relay fits. The Rules:-
1 Buccaneer comes back alive. 2 Chicks dig scars. GB260 |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2278 ![]() ![]() ![]() |
Why is it more difficult ? Do you have a different dash ?
The flasher relay is buried under the transmission tunnel behind where the other relays are and this needs to be removed for access to this one relay. The Rules:-
I have the mobilecentre relay fitted and it works flawlessly
I will be fitting LEDs to my off-road trailer |
Ah, I see, that explains it then ☺ Thanks Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Will you ned to fit load resistors to your trailer lights The trailer must be using incandescent bulbs or LED lamps with load resistors for the Trailer light to flash. It cannot detect trailers solely on LED lamps it will make them flash ok but will not flash the trailer light as the extra load is too little to detect. I do not know of a relay that will 'see' LED lights on a trailer and light up the warning light, although the RDX relay will flash the trailer lights it will not light up the warning light, but I suppose you could live with that. |
Your not supposed to tow with it not working though I think.
Most likely would need load resistors indeed. But depends on the resistance. |
or fit a buzzer and forget about the dash light
mine (buzzer) works with leds or bulbs (have trailers with both) cant see the point in leds with resisters |
I cannot see the point with resistors either nor that some people put a 20 Wat bulb into the circuit
Tis a easy job however now that I have fitted a proper head unit and heated seats it will take a little longer to remove ![]() |
I was going to test first with a led tailboard
I'm not worried if the dash light illuminates Thanks for the heads up ![]() |
Just follow the instructions to the T it works a treat
