Home > Puma (Tdci) > Clutch slave cylinder |
Artturi Member Since: 27 Apr 2011 Location: Tampere Posts: 3 |
Hi,
I just drove my Defender -08 (44000kms on the clock) to the workshop because slave cylinder started to leak. Not nice. The replacment part is not very expensive, but it takes some mount of work. The clutch will be rplaced too, even though it works, it is still original. A pessimist is just a badly informed optimist |
21st Aug 2014 5:02pm |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 |
Hi Artturi, arranged for the truck to be picked up tomorrow 9:00 am, should be at garage Monday afternoon. Will see what they have to say. At least they already ordered the spare parts they need. (Bit of a surprise that)
Cheers! Stephan |
23rd Aug 2014 12:47pm |
Got the truck back about 10 days ago.
Took almost 5 weeks to get the repair done - waiting for spare parts thing. Whole thing done on warranty, garage replaced clutch master and slave cylinder. Also had a lot of small things sorted while they had the car sitting around. Yesterday .... clutch gone again. This time clutch master leaking DOT4 ... faulty part. Not too happy at the moment. |
4th Oct 2014 5:49am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3648 |
that's poo and must be extremely frustrating DEFENDER 90 TDCI XS,
4th Oct 2014 6:36am |
if have problem clutch cylinders all was change both, if one has a problem the other will follow soon save time too
4th Oct 2014 7:55am |
Frustrating indeed ... but what to do?
The dealer did replace both slave and master, but as far as I can make out the master cylinder had a weak point and developed a crack at the underside after about 500 kms. The oil seeps out and runs over the bulkhead. Since it is such a hassle to get the car from this island to Penang, the dealer agreed to send me a replacement part so a local mechanic can install it. Wonder how long it will take for the spare part to arrive here ... Cheers Stephan |
4th Oct 2014 2:17pm |
Got the truck back ... the new clutch master cylinder installed. Hope this is it ... since 18th of August only had use of the car for about 10 days...
Wife grumbling and talking about reliability of the Isuzu D-max her friend has ... Good thing this didn't happen in the middle of nowhere ... for the next couple of weeks there will be a container of DOT4 in the car, just in case ... |
15th Oct 2014 8:30am |
