![]() | Home > Td5 > Ventilation blower anemic, is that normal? |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
On my TD5 (without aircon) the blower on the highest setting delivers a fair blast of air.
Not sure if the aircon restricts the flow a bit..? cheers simon |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Check to see if your hoses behind the dash have come off.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5805 ![]() ![]() |
No. Normaly fully on is too much. Something's wrong.
Andy |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 340 ![]() ![]() ![]() |
Ok, will check. Any pointers as to how I best check this? Do I need to remove the dash or parts of it, on can it be done from the footwells?
Can you hear the fan?
Just to check, but fan is fully on with left knob down. Andy |
I am not with the car right now, but will check tomorrow. I appreciate you guys for replying and trying to help!
If the fan is turning (blowing) and there is nothing coming out of the vents then its sure to be something to do with the hoses. try putting your ear to the dash with the engine off to see if you can hear anything, also check your air vent if the heater can not suck in air there is nothing to circulate
aus10RRW Member Since: 19 Oct 2013 Location: Aberdeenshire Posts: 20 ![]() ![]() ![]() |
Had a very similar issue with our TD5, check the resistor on top of the blower, water can get into it and corrode the resistor.
I checked and the fan is spinning nicely, the air intake up on the fender is not restricted and air is being sucked in. When I block the intake with my hand, I feel considerable suction, albeit not comparable to a vacuum cleaner.
However, I feel there's more air being sucked in than being blown out into the cabin. When I direct the air to the windscreen, I only feel a gentle breeze. When I slide the lever the other way, I hardly feel any air at all, anywhere. I guess it should go to the footwells, right? Maybe my aircon is obstructing the air? Based on your suggestions, I suspect a hose has come off, or the valve that directs airflow (windscreen or footwell) is faulty. I tried to figure this out and started to partially remove my aircon-unit, but still could not determine the cause without having to unmount more parts of the dash along with it (for which I have no time now). Thanks for the help so far (either by reply or PM), I guess this will have to wait until I have the time to remove the dash, which I plane to anyway, as I want to have a good look at the bulkhead. Thanks again. |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
I would check the cable operated lever first. Have a look down the left side of the heater unit and you will see it. It operates a flap which allows air to flow into the cabin.
I believe, although I could be wrong, that the fan lever in the cabin performs two functions, the first to open and close this flap and the second to switch the fan between its two speed settings. 2002 110 td5 |
