Home > In Car Electronics > Fitting DLR's to come on with ignition
Sportacourt
England 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Guys
I want to wire in a set of LED daylight running lights to come on with the ignition on my 2010 puma. Does anybody have any suggestions where I can pick up the live feed for this, are any of the spare fuses on the panel suitable? or is there an easy option?
Post #352293 18th Aug 2014 12:35pm
munch90
why not use a drl controller just 2 wires to battery and 1 to sidelight
don't forget if they come on with ign they must go off or dim when sidelights are switched on by law ,so you cant have them on all the time anyway
having them come on with ign and on all the time day and night would be illegal
Post #352296 18th Aug 2014 12:42pm
Sportacourt
thanks Munch90,,
good point, I had totally overlooked, just checked out wiring diagrams on dlr controllers, and looks fairly straight forward. Just to fully understand does this mean that sidelights have to be on for dlr's to work or will they come on with ignition, then dim etc when side/headlights are used
Post #352303 18th Aug 2014 1:14pm
munch90
ign on = no lights
start engine = lights come on
sidelights on = drls dim or go off (I prefer the ones that dim )
headlights and sidelights = drls dim or off
switch off engine so ign off = some controllers allow the drls to stay on for about 30 secs as a see you home function
have a look at a few diffirent controllers as vary on functions , some dim the lights others turn them off etc
Post #352305 18th Aug 2014 1:25pm
Sportacourt
excellent, many thanks, much appreciated!
Post #352310 18th Aug 2014 1:46pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I have fitted twin DRLS. One set goes off after about 30 seconds, the other can be 5 minutes or so. Shocked
Where's the best place to pick up an ignition feed rather than the + battery so they go off with the ignition?
Thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #390318 19th Jan 2015 7:31pm
JAY BOY
Wales
Use the white wire on the ignition barrel Thumbs Up
Post #390319 19th Jan 2015 7:33pm
carrotbay
Thumbs Up 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #390337 19th Jan 2015 7:50pm
Davie L
Scotland 2008 Defender 90 Puma 2.4 HT Orkney Grey
Thanks
Was this a Urban truck one by any chance?
Ive just recieved my twin drl bumper from them and also need to know wherd i can pick up a live feed goid enough for the two seperate controllers (each controller has two drls) so four all in.
Davie
Post #390382 19th Jan 2015 9:14pm
munch90
Thanks
if they both running off the same battery then maybe a problem with one controller ?
Post #390387 19th Jan 2015 9:18pm
carrotbay
Yes, from UT. I also have a problem now with radio interference. .. I'm going to try the negative going back to the battery instead of the earth on the bulkhead. Perhaps a dodgy module. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #390439 19th Jan 2015 11:30pm
carrotbay
Still haven't managed to fix this. Sad
Tried in line suppressors, ferrite things .. all sorts. As soon as the DRLs come on the DAB radio looses it's signal. (+ from the battery and - to the bulkhead earth point)
I've pulled the fuse on them for the last month or so as needed the radio for my commute, but now getting questions from SWMBO about why the lights don't come on the expensive present she bought Embarassed
Need to fix it .. any ideas? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #420475 1st May 2015 5:38pm
Davie L
Hi mate
As you know I bought the same twin drl bumper as yourself.
Where did you put the modules? I've got mine secured in the engine bay and don't get any interference with my radio, Coming and going from the + and -
Once ignition is turned off and vehicle locked the inside lights (closer to the ref plate) go out first then after 60 seconds or so then the outsides go out other than this is all scratched from grit kicked up in the A roads I would have thought it wouldn't at least be better than this considering it happened on one trip!
I wouldn't buy another.
Davie.
Post #420479 1st May 2015 6:11pm
carrotbay
I've got the modules mounted together just to the right of the radiator inside the engine bay. I'll take it all apart and find a better place for the modules and re-route the + and -.
I have a little chipping on the bumper but not as bad as yours by the sounds of things. Neutral 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #420483 1st May 2015 6:24pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
There is a good article covering this very subject in May issue of LRO International (fitting a DRL bumper) Page 146. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #420604 2nd May 2015 10:06am
