![]() | Home > Puma (Tdci) > Brake pedel travel |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
Sounds like the wheel bearing is lose allowing the wheel to wobble and push the brake pistons back. A couple of prods on the brake pedal pushes the pistons back to the right place, until the wheel wobble knocks them back again.
Jack up the car and see if the wheels wobble. cheers simon |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Im not being nasty but I would check the wheel the hub seal was changed on first as that has been disturbed
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Daz Member Since: 10 Aug 2014 Location: west yorks Posts: 46 ![]() ![]() ![]() |
Hi jacked up the wheels and there is no play on the bearings at all it all nice and tight , Any ideas ?
![]() cheers daz . |
Are you losing break fluid? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Hi no brake fluid loss and no air in system . Could it be master cylinder , .
If you suspect the m/c get somebody to press the brake pedal and look for bubbles or fluid moving about in the reservoir,if the seals have gone/going,the brake fluid re-circulates back into the reservoir instead of being forced down the brake lines.If its none ABS,an oem m/c is about £60ish, ABS will cost nearly treble. Pov.spec,ftw. 2006, 110,TD5.
Hi jimbob7 , When I press the brake pedal the fluid rises in the reservoir does this mean its the master cylinder that's at fault . cheers daz ..
Hi just to update , Ive replaced master cylinder and can confirm all is good and well . Thanks for your help .
Cheers daz .. |
