Home > Puma (Tdci) > Brake pedel travel
Daz
United Kingdom 2007 Defender 90 Puma 2.4 HT Java Black
Brake pedel travel
Hi all after owning my 90 for 5 weeks and had to replace water pump , Hub oil seal and sort out alarm its now developed excessive brake pedal travel but not all the time most times its as it should and then next time you brake the pedal travels almost to the floor but still brakes and if you pump pedal once its back to normal , Theres no air in system and pads are like new . Has anyone got any idea what could be at fault . Its a 2007 puma .
cheers daz
Post #352171 17th Aug 2014 6:04pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Sounds like the wheel bearing is lose allowing the wheel to wobble and push the brake pistons back. A couple of prods on the brake pedal pushes the pistons back to the right place, until the wheel wobble knocks them back again.
Jack up the car and see if the wheels wobble.
cheers
simon
Post #352175 17th Aug 2014 6:26pm
munch90
^^^ Thumbs Up
Post #352178 17th Aug 2014 6:48pm
grafty99
Im not being nasty but I would check the wheel the hub seal was changed on first as that has been disturbed Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #352249 18th Aug 2014 7:38am
Daz
Hi jacked up the wheels and there is no play on the bearings at all it all nice and tight , Any ideas ? Rolling Eyes
cheers daz .
Post #352423 18th Aug 2014 8:54pm
roel
Are you losing break fluid? Roel
2003 90 Td5 (2009-now)
Post #352478 19th Aug 2014 10:02am
Daz
Hi no brake fluid loss and no air in system . Could it be master cylinder , .
Post #352854 21st Aug 2014 9:11am
jimbob7
If you suspect the m/c get somebody to press the brake pedal and look for bubbles or fluid moving about in the reservoir,if the seals have gone/going,the brake fluid re-circulates back into the reservoir instead of being forced down the brake lines.If its none ABS,an oem m/c is about £60ish, ABS will cost nearly treble. Pov.spec,ftw. 2006, 110,TD5.
Post #352858 21st Aug 2014 9:37am
Daz
Hi jimbob7 , When I press the brake pedal the fluid rises in the reservoir does this mean its the master cylinder that's at fault . cheers daz ..
Post #354043 27th Aug 2014 7:34pm
Daz
Hi just to update , Ive replaced master cylinder and can confirm all is good and well . Thanks for your help .
Cheers daz ..
Post #356163 6th Sep 2014 8:23pm
