Home > 130 > Advice from 130 owners please, plus restoration thread
Page 2 of 6 <123456>
Rosso_NI
United Kingdom 1993 Defender 110 2.5 n/a Diesel ST Galway Green
Got the correct rear x member brackets today so making progress. Also decided on power plant
Just need to get it lifted out of a Classic LSE first, drove it today, with auto box and stainless exhaust, only soundtrack you need Thumbs Up so 3.5V8 manual coming out and 4.2V8 auto going in. Im sure there will be a few headaches to come but up for the challenge
Post #331617 17th May 2014 6:56pm
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
Nice Razz He who dies with the most toys...wins!
Post #332107 19th May 2014 8:02pm
Rosso_NI
3.5V8 Ready to come out
High cap makes great storage for parts Thumbs Up
Found a set of these 569204s not sure about them yet, possibly get them blasted and painted and put my BFG muds on before i make my mind up.
Post #335610 4th Jun 2014 8:26am
Rosso_NI
Thanks for your comments and advice. Thanks to AndrewS i now have the correct brackets i need for high cap Thumbs Up i just need to get to the stage where all spare parts are out of it so i can re mount the body.
I have been working away, but its all mechanical bits and pieces, looking forward to the stage where i can start to bolt on some tasty bits Cool
The 4.2V8 i got was in need of an overhaul, had a bit of a tapping noise which i thought could have been worn camshaft, lifters etc but have since found the source of the problem.
One very bent push rod
So needless to say engine is completely stripped down and will be getting loads of new bits thrown at it including upgraded camshaft
Shocked
Post #337863 13th Jun 2014 8:17am
Rosso_NI
After reconditioning cylinder heads and some new parts thrown at it, the V8 is starting to get bolted together again Thumbs Up
More detailed post here http://www.defender2.net/forum/topic30606.html
Post #349364 3rd Aug 2014 10:55pm
Pickles
Very interesting project, she will be very nice with a 4.2 upfront.
keep us up to date please.
Pickles.
Post #349369 3rd Aug 2014 11:51pm
mentalmickybikes
United Kingdom 1993 Defender 90 200 Tdi HT Barolo Black
just came across your project
i have 2 of these 130s
just got the chassis back from galvinisers
dont know what i am goin to end up with
not decided whether to sell or
put away until i finnish some others first
regards
mike
Post #349507 4th Aug 2014 8:03pm
Rosso_NI
Sounds like you have a few projects on the go mentalmicky Very Happy
This is my first 130 and have never driven one, so when this V8 fires up will be the first time i also drive a 130 Shocked
Post #349544 4th Aug 2014 10:30pm
Pickles
Forgot to mention, make sure you put a nice exhaust on this beast, so you can actually hear those eight cylinders working.
Pickles.
Post #349552 4th Aug 2014 10:48pm
Rosso_NI
Don't worry Pickles its on the cards, have 4 branch manifolds for it and old sports exhaust off the LSE (doesn't look the best) that the engine came out of, which i am hoping to modify Thumbs Up
No point having a V8 and not hearing it Very Happy
Post #349553 4th Aug 2014 10:58pm
Rosso_NI
Starting to look a bit more complete
Post #350650 9th Aug 2014 8:05pm
Ronin
United Kingdom 2014 Defender 90 Puma 2.2 ST Keswick Green
What a fantastic project, proper man stuff!
Looking forward to seeing it all completed.
Am jealous that your engine will be nearly twice the size of mine Shocked
Post #351749 15th Aug 2014 11:59am
Rosso_NI
After over a month have started to tinker with project again. Managed to get it rolled into middle of drive and now have good access to both sides.
Kinda got fed up looking at it like this Sad
Need to get some bits bolted back on to it, so have stuck on another new type door, got wiring loom back into it and have gathered up some parts nothing to exciting to look at though.
Engine wise there has been some progress and am hoping to get more done this evening, water pump and inlet manifold with any luck.
Will hopefully have a few more pictures to update tomorrow.
Thumbs Up
Post #358676 18th Sep 2014 3:44pm
Rosso_NI
Inlet manifold and water pump done, not sure about paint job on manifold, did it ages ago Shocked
Next on list is to sort out pumps, pulleys, belts, alternator etc. hopefully try to simplify if possible.
Post #358826 18th Sep 2014 11:47pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Just keeps getting better Thumbs Up
Steve
Post #358828 18th Sep 2014 11:53pm
