Home > 130 > Advice from 130 owners please, plus restoration thread
Page 4 of 6 <123456>
Rosso_NI
United Kingdom 1993 Defender 110 2.5 n/a Diesel ST Galway Green
Just a small update to anyone interested
Was off for St Patrick day yesterday so pulled 130 away from its corner and got stuck into a few jobs.
For a change i tidied a few interior jobs up fitted wiper motor, attahed bottom dash, fitted rear door card and plastics, front door stops done, plus a general tidy inside
As for the V8 its a touchy subject, beginning to have doubts about going down this road, but i am sure i will get to the bottom of it
Any advice will be appreciated or even who is V8 experts on here that i can PM
Its getting fuel
Timing is accurate
Good healthy spark
Compression is good given that engine has not been run since rebuild
Although it turns out when we were testing compression it is spraying fuel everywhere so looks like it is over fuelling
So essentially it is flooding everytime we try to start it.
Not yet explored
ECU although not tested they generally do not give problems
Need to test fuel pressure however original RR classic pump was used
Injectors could be leaking but drove RR before stripping engine down ran perfectly
Also a chance that that injectors are pulsing too quickly......
ANY IDEAS ???????
Post #408789 18th Mar 2015 7:03pm
Rosso_NI
Report from Saturday great weather and with no joy with V8 thought i would tinker with interior
Interior When i picked it up
Now Smile
All in a days work Thumbs Up
Luckily there was TDCi rear seats in it when i bought it off my mate
Post #417429 19th Apr 2015 9:21pm
Rosso_NI
Report from Sunday
It lives Very Happy the V8 after alot of coaxing (fresh battery, snap on jump back and a slow battery starter/charger) nearly burning through a new starter motor and a mate of mines mechanical expertise after about 30 mins of churning she finally coughed into life Thumbs Up she now starts like an old 200tdi first turn of the key.
Sounds awesome as there is manifolds but no exhausts, have a few more things to do it until i can run it properly though, alternator bracket vibrates and moves around quite a bit as engines turns over, worried it might fire the belt off, plus need to install collant bottle, buy some various pipes, hoses etc. bleed system properly and then i should be able to run her properly.
Will take a video and post it somehow no idea how to do it.... But will work something out
For me project has turned a real corner and i have a new found motivation for it, still a shed load of axle and chassis work to do before i drive it in anger though
Thanks for reading hope to post some more stuff very soon Whistle
Post #417439 19th Apr 2015 9:39pm
Rosso_NI
I think i have managed to upload a small video to you tube Question nearly took as long to work it out as it did to get V8 going Whistle
Hopefully it works only a taster of whats to come, four branch manifold and y piece exhaust only at this stage, no centre or rear box. Will post a few more videos as build progresses, dont be expecting any edited masterpieces though Thumbs Up
Post #421172 4th May 2015 8:13pm
Rosso_NI
Im stunned it actually worked not the best with technology Shocked
Post #421174 4th May 2015 8:15pm
shaggydog
Fantastic!
Always good when after hours of scraped knuckles, swearing and grot under your nails you can stand back and see it running again.
Great build, keep your updates coming Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #421177 4th May 2015 8:23pm
mk1collector
Excellent Thumbs Up love seeing updates on this Ray
My build thread
Post #421190 4th May 2015 9:09pm
Rosso_NI
Shaggy and Mk1 thanks for the comments it is great to see some light at the end of the tunnel.
With the longer nights i hope to make some good progress over next month or so Thumbs Up
Thanks to sailingtom giving me a heads up and Colin700 for selling them to me i now have these to bolt on when i can get them over from the UK, have been after a set of these for ages.
Post #421674 6th May 2015 7:39pm
Rosso_NI
Not much to update as i am currently waiting for a mate of mine who has a workshop to get a 2 or 3 day window when he is not flat out to throw 130 on his ramp.
The plan for when it is on ramp is to do the following
Rear diff
Rear half shafts and flanges
Handbrake Drum assembley
Rear prop shaft
Fabricate exhaust joiner piece
Fabricate transfer box levers
Check serviceable items brakes bushes etc.
Oh yeh and if i have time brush down chassis and waxoyl
I have purchased a couple of items since last update not particularly exciting but an improvement. I was always going to do away with Land Rover fan as i dont feel that they were particularly good and as we know V8s like to run hot. So have gone down the electric fan route
Two electric fans in place
Thermostat is to be wired in but as you can see is in top radiator hose this will control the two fans and is temperature adjustable
As always thanks for your interest and comments hope to have more updates soon Thumbs Up
Post #427197 30th May 2015 6:51am
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
Looking like your getting somewhere with it. How did you get on with the tub and brackets?
Post #427370 31st May 2015 6:36am
Rosso_NI
Thanks Chris yes got brackets sorted and tub now sitting where it should be.
Trying to make my mind up whether to keep eye out for decent second hand tub or refurbish the one i have. Plenty of stuff to do before that though.
Post #427375 31st May 2015 7:02am
MuddyChris300tdi
I'm going to try and sit down tonight and start my own thread. My 130 is in a similar state to yours and the list of bits that need doing keeps growing.
Post #427554 31st May 2015 5:26pm
Rosso_NI
This will not sound like anything major but managed to drive 130 under its own power for the first time about 10 m forward and 10m back
This is the first time in over 5 years that this 130 has moved under its own power so although 10m may seem minor for me and the 130 this is a major milestone Thumbs Up
Also managed to plumb and test power steerin, wired up electric fans and thermostat and ran engine up to operating temperature with fans kicking in and out as they should. Again first time ran to temperature.
Hand brake assembley fitted only to find i have wrong cable as its to short.
Other than that a sucessfull days work Thumbs Up 1993 Defender 110 Ex Military soft top, with a long wishlist already
Post #427685 1st Jun 2015 7:22am
mk1collector
Excellent work, more pics please Mr. Green Ray
My build thread
Post #427703 1st Jun 2015 8:38am
Greggster
United Kingdom 2007 Defender 110 Puma 2.4 HT Alpine White
Excellent work indeed, very inspiring when people take on projects like this. I think I'd have had a melt down by now! Whistle Mr. Green
Post #427825 1st Jun 2015 4:54pm
