![]() | Home > Puma (Tdci) > Resonant clattering - injectors? |
1989964 Member Since: 11 May 2014 Location: cheltenham Posts: 57 ![]() ![]() ![]() |
look at the small print, the software comes with the cable...
Or do you reckon this kit will do the lot?
http://www.ebay.co.uk/itm/Jaguar-Land-Rove...19f1788860 Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
its the same thing, 35 euros is better though. I got mine through aliexpress.
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
this is the one i bought, arrived in about 5 days
http://www.buyobdtool.com/wholesale/jaguar...goose.html |
looks like the reviews for mine are better, probably more complete software, mine worked straight out of the box
but does that include all the diagnostics/programming software? Tell someone you love them today because life is short.
yes it actually comes with 3 DVD's
Thanks - that's brilliant! So that's on its way. Just found out from Pete that if I make any firmware changes I should erase my BAS console then go through the remapping process again afterwards. PITA but hopefully worth it.
I can't decide whether to change the vcv immediately of just try to re-teach the old one first... Please do you have a part number for the vcv? Was it really p*$$ easy to change? Do you have any tips? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Try to relearn first as I bought one and it turned out not to need it, i just sold it on eBay too, doh
TY
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
Ze
Just a thought I was having a little look around under the bonnet earlier and although all the turbo beat shield bolts were tight I noticed a 'tear' in the corner towards the front / radiator and I could imagine this making a certain clatter type noise at the right speed / resonance??? - like I said Just a thought? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
Mines also split in this place.
Do u reckon it makes a noise?
