Home > Puma (Tdci) > who's fitted an EGR? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20350 |
Just ignore that, mine was the same.
They've no doubt improved them in various ways. |
5th Aug 2014 12:43pm |
Marco Member Since: 30 Jul 2014 Location: Hilversum Posts: 6 |
Thanks!
5th Aug 2014 12:50pm |
You may notice that it acts slightly differently on shut down too.
5th Aug 2014 3:49pm |
Jist is to be progressive and gentle but not go at it like a bull in a china shop.
One of those things that once you've done once you could do it time and time again in next to no time. Not that you'd want to. |
8th Aug 2014 11:34pm |
also you can stick the gaskets to the egr before fitting , makes much easier job when trying to line everything up !!! small amount of glue round the bolt holes , ONLY SMALL AMOUNT AND MAKE SURE YOU DONT GET ANY IN THE VALVE AND ITS NOT TOO THICK TO STOP VALVE BEING TIGHTENED DOWN AND SEALING !!! |
9th Aug 2014 7:31am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
FYI, someone in ZA has managed to disconnect the EGR without the MIL coming on: http://www.4x4community.co.za/forum/showthread.php?t=159476 --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Aug 2014 11:56am |
I've not yet started the job, and do agree it's not rocket science to replace. Have done much more on Landies but not yet on this 2.4 Puma one. I've cleared the logged fault code of the open EGR actuator and it has not come back. So wonder if I should replace the EGR anyway as it is already on the shelf. Vehicle is 2.4 Puma, 2007 @80500 km. So relative low mileage compared to age. Not sure about the average lifespan of the EGR?
11th Aug 2014 7:00am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1999 |
Mine went faulty at 50k miles (80k km) so about the same as yours, noting mine is on a 2.2 so different valve and far more awkward to get at the fixings, but I got their in the end.
If you have one on the shelf ready to go I would change it out now, else it can get worse and put you in limp mode at the worst time, ie miles from home. |
22nd Dec 2021 4:59pm |
Nino4x4 Member Since: 09 Apr 2019 Location: Madrid Posts: 13 |
The EGR can be canceled in two ways, the first, which is the normal one, is EGR off or closed, which is what they usually ask me, and in this case it is not necessary to put a plate since it is closed and there is no air passage, and the second way is if you want to remove and disconnect electronically that can also be done by overriding the ECU
22nd Dec 2021 9:18pm |
blackrock Member Since: 01 May 2022 Location: Hampshire Posts: 57 |
Just got a new EGR and was expecting gaskets to be supplied with it. Have I got to order gaskets or are they re-usable?
22nd Aug 2022 12:19pm |
You really want new gaskets, they arenโt expensive. $W33T $0U7H3RN $UG4R
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
22nd Aug 2022 3:46pm |
On the subject of gaskets, are the britpart ones any good. Are the LR and britpart gaskets actually the same part in different bags or is it worth spending the extra on LR ones?
1st Sep 2022 11:03pm |
For the 2.2 the EGR OEM is Pierburg. They supply ford who in turn supply to LR. You can even see they have ground the FOMOCO casting off the valve when pierburg sell it direct.
I strongly suspect pierburg are OEM for the 2.4 EGR as well. You should therefore be able to get the OEM quality pierburg boxed gaskets cheaper on the open market For my 2.2 I found buying the pierburg badged valve less than half the price of the LR boxed one and itโs exactly the same valve but with included gaskets. So if your are going to get a new valve then worth looking up the pierburg part number and seeing if it is lower cost than from LR or Ford. |
2nd Sep 2022 12:11am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 484 |
Using the truck only on long distance trips I cannot report any EGR related problem (more than 100K miles).
2nd Sep 2022 8:13pm |
