Home > Group Buys > Nakatanenga Stainless Wheel Carrier - Group Buy
Sign Up
(24)
User Registered Confirmed
MartinK11th Jun 2014 2:18pmMartinK is confirmed
Inigo11th Jun 2014 2:24pm
jomara11th Jun 2014 2:27pm
a13x11th Jun 2014 5:11pm
ChrisJ11th Jun 2014 6:45pm
Dave Bellis11th Jun 2014 9:40pm
GEllis11th Jun 2014 10:43pm
SFDM11th Jun 2014 10:48pm
bear10012th Jun 2014 9:57am
TheWarden12th Jun 2014 10:03am
McGeordie12th Jun 2014 10:09am
ken12th Jun 2014 12:10pm
Andrew james12th Jun 2014 3:13pm
Bristol 90XS12th Jun 2014 8:53pm
bob neville13th Jun 2014 12:39pm
H3nry13th Jun 2014 4:18pm
Mud Dog24th Jun 2014 10:36pm
kateb30th Jun 2014 5:51am
captain slow8th Oct 2014 12:18pm
simon6711th Nov 2015 11:45am
Co115th Dec 2019 12:52pm
defenderandwe17th Jan 2021 7:59am
sewinelwy7th Apr 2022 1:29pm
GregOb'19th Apr 2022 8:25pm
Page 5 of 6 <123456>
Andrew james
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
Received my carrier and gas strut today and fitted them already. Really easy to do and set up. As already mentioned the quality is excellent. Thumbs Up
Thanks to Barbara and Brendan for organising it all Bow down
Post #350204 7th Aug 2014 7:42pm
leeds
Hi Andrew, you forgot to thank Peter who has them made Razz
As a matter of interest how long do you think it takes just to fit the wheel carrier?
What do you think is the hardest part in fitting this wheel carrier.
I have fitted a couple now, normally I get interrupted several times so I would be interested in your view of time taken and what is the hardest part involved in fitting it.
Thanks
Brendan
Post #350233 7th Aug 2014 8:59pm
Andrew james
You are right Brendan, I forgot Peter, however the reference to the excellent quality of the product hopefully makes amends for that faux pas.
Fitting time was around two hours including the gas strut. Switching between the two allowed a bit of time for the primer and spot of hammerite in the drilled areas to dry. The cross member was warm in the sun so it did not take long.
There was no real difficulties, other than the kids interrupting! Perhaps the instructions may be clearer particularly the pictures. What got me was the use of the washers in the bolt kit. That was sorted really by referring to posts from previous installations. The really big washers i used behind the crossmember, out of view. It worries me when there are bits left over Laughing There was a couple of creamy white items not visible in the pictures or mentioned in the text. I assumed they needed to be pressed into the holes that the adjustable arms fix into on the fixed plate on the door and the swing arm. I was not too worried about the position of the plate on the cross member as there seems to be plenty of adjustment elsewhere.
I did put a light spray of grease behind the attachment to the cross member, hopefully to reduce corrosion.
Time will tell if I have set it up correctly, regarding rattles etc. It feels pretty solid, but a bit of tweaking may be needed. However its all simple to adjust.
I was very interested with the packing in the box, unusual to have maps to protect the product. The kids loved them!!! Rolling with laughter
Post #350249 7th Aug 2014 9:38pm
leeds
We do aim to please the whole family Thumbs Up
Hopefully the maps will help them in their geographical and language knowledge Thumbs Up
The holes that are enlarged should have decent rust protection measures taken. Ideally the whole of the rear cross member could be cleaned, painted and rust prevention measures taken prior to fitting the wheel carrier..
Yes the bottom 'saddle' and rubber bump stops might need tweaking. It can be easier to adjust the wheel carrier with the spare wheel off.
Feedback from customers improves our knowledge and helps us to improve advice and instructions to future customers.
Brendan
Post #350262 7th Aug 2014 10:32pm
McGeordie
United Kingdom 2014 Defender 110 Puma 2.2 USW Montalcino Red
Its good to hear how others are getting on so thanks for sharing, any hints and tips always beneficial...now very excited for Mr UPS to arrive at some point soon...although won't be able to fit until the 110 arrives in Sept...I hope!
Post #350502 9th Aug 2014 10:20am
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
Just fitted the wheel carrier
Fitting was fairly straight forward adjustment was a bit fiddly but then I like things spot on...the stops need to be tight against the door plate. It took about 2 to 3 hours in total...The wheel carrier is of quality build and the instructions were fine...
My only concern is maybe getting spare parts should things wear out etc,,,,,and are there any serviceable parts.
Many thanks
Dave
Post #351313 12th Aug 2014 9:21pm
Dave Bellis
Wheel carrier
Forgot to thank Brendan Barbara and Peter well packaged, good delivery all in all very pleased with the product....
Thanks
Dave
Post #351314 12th Aug 2014 9:24pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Eventually got around to fitting my wheel carrier today, everything went well except for one of the M8x25mm dome headed screws which decided to bind on the excess underseal which was present on the threads, after a bit of swearing I managed to round out the head with my Censored Teng Allen drivers leaving me to drill it out !! Evil or Very Mad
All in all even with the messing around and the time spent on the fine setup it only too 3 hours which included painting in the drilled out holes, washing and waxing the door and then a full wipe over of the carrier and cross member with ACF50. Very Happy
Really happy with the quality and it was relatively easy to fit and setup (even with my wee problems and the still soft Dinitrol) Rolling Eyes
Thanks for the great service Brendan Thumbs Up
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #358527 17th Sep 2014 7:23pm
Co1
Any danger of resurrecting this group buy again?!
Post #806294 15th Dec 2019 12:52pm
You'd have to approach Brendan directly as he doesn't sponsor here anymore. Darren
Post #806303 15th Dec 2019 2:24pm
defenderandwe
United States 1997 Defender 110 300 Tdi SW Santorini Black
I wish this would come back to the forum for a 2.0.
Post #879042 17th Jan 2021 9:32am
The Crab Botherer
United Kingdom 2001 Defender 90 Td5 ST Nato Green
Me too!
i would love one.
Post #894718 29th Mar 2021 4:20pm
Likeomg
would also be interested...
Post #894730 29th Mar 2021 5:24pm
s55shh
and me
Post #894738 29th Mar 2021 5:44pm
Sulisuli
Probably best to message Brendan direct as he isn’t on here as much now, or trying posting about non road legal lights or LED bulbs and he appears like a genie from a lamp Rolling with laughter total respect Brendan if you read this post fella hope you and Barbara are keeping safe n well. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #894752 29th Mar 2021 6:35pm
